Looks like 68609125AD is the 4-aux switch bank.
Then you would have to do like previous years for adding aux switches- populate all the wiring, fuses,and relays in the aux PDC, or have
@Florotory build you the kit for it. You’ll also need to check to see if the connector that would plug into the switch bank is present in the dash (if not, that wiring will have to be built also). Link below for reference of what’s involved in adding the wiring.
Then, after all that, comes the long wait for being able to program anything on these trucks.
Just for reference, I informed the alfaobd developer last October that he is able to add the 2025 1500 to alfaobd, but he’s still working on it. The 2025 Heavy Duty Rams aren’t even in the latest “cracked” version of CDA6 (this is the pirated Chrysler engineering software that the alfaobd and JScan developers use to model their apps after), so we have to first wait for someone to “crack” a newer version of CDA6 until these 2025 HD Rams can be added to alfaobd for bcm programming.
There are quite a few threads about Adding Aux switches and AlfaOBD to our trucks out there. I did hours of reading them and watching numerous videos on it as well as messages back and forth to get this installed on my truck. I wanted to make a DIY for someone else that wants to do it and keep it as factory as possible yet fairly easy to accomplish. Here are the steps from gathering the needed parts , programming the truck.
UPDATE: Below is the video for making the harness. Ill add the video of installing the harness as soon as I get it edited.
Here is Part 2 of the...
