2025 ram 3500 Limited option missing
Any luck with this. I received a thank you for purchasing flyer from Ram last week and this was in it. Apparently it is possible?1768858018196.jpeg
I randomly came across this review of a 2025 1500 RHO and I noticed that the truck had the trailer reverse guidance AND the four AUX switches. See screen shot below from YouTube video. So unlike the 2024 and under models, it looks like the AUX switches will fit. started looking around at dealer RHO interiors to make sure that one truck in the YouTube video wasn't some pre production model and sure enough I found the aux switches with the trailer reverse guidance module again. (2nd pic.). So these aux switches will definitely fit if you also have the trailer reverse guidance. now it's just a matter of finding some part numbers!
I knew I saw it somewhere! Thank you for this. Looking to order a '27MY and diving through all the aux switch threads and current '26MY Order Guides.
Any luck with this. I received a thank you for purchasing flyer from Ram last week and this was in it. Apparently it is possible?View attachment 93082
Funny enough, at least currently, you can't even order the IP Mounted Aux Switches on a '26MY PW; at least on the U.S. B&P Configurator.
Edit: That photo is of a '27MY, I know this because the Press Release of the Cummins PW uses the same photos (and that's for '27MY only). Maybe that means for '27MY you can equip both the IP Mounted Aux Switches AND the Reverse Trailer Steering.
I wouldn’t put any weight behind those photos. Ram’s marketing images are always computer generated. Many of them are the same photos from 2019 with new bits pasted in.
Any updates yet from anyone who has successfully installed the IP mounted switches? My 2026 is the same, says it has the prep, doesn't have the switches nor the way to program them in Commercial Settings. I think I'm just going to install a Switch Pro and use the SDHQ mount near drivers left knee.
I just went with the Garmin power switch.
