Ironic, since Gentex actually makes the digital rear view mirror that Ram 1500 trucks use.I called the Gentex support and they said they did not have anything that would work for the rams. that was a couple months back.
Yes, for the 23-26 models, Ram introduced the Magna, which is the 3.0 digital rear view mirror.So you mentioned the ram 1500 may use the Gentex. Ram went with the magna clear view system on the ram 2500 and 3500 23-26 trucks. Interesting.
Well that sucks. I was about to buy one. I thought because it has its own camera I could just install the mirror, give it power and use the camera that comes with it that it would work. I seen others install it in other vehicles and it worked.I called the Gentex support and they said they did not have anything that would work for the rams. that was a couple months back.
That’s all it is, and that one should work in any vehicle. As long as you can come up with a way to mount the camera. Also, looks like it’s set up with a wedge mount, so you’ll need a wedge-to-twist off mount adapter, and it should be all good.Well that sucks. I was about to buy one. I thought because it has its own camera I could just install the mirror, give it power and use the camera that comes with it that it would work. I seen others install it in other vehicles and it worked.
Thanks for the reply. I think I am going to bite the bullet and buy it. I live in Toronto, Canada so it’s going to take a couple of weeks for it to come to me. See what happens I guess. I can mount the camera with double sided tape at the rear window. The only problem I see is to find a way to mount the mirror. Hopefully I can open the factory mirror I have now and the gentex and swap mounts like you said and posted a picture on here a couple of years ago.That’s all it is, and that one should work in any vehicle. As long as you can come up with a way to mount the camera. Also, looks like it’s set up with a wedge mount, so you’ll need a wedge-to-twist off mount adapter, and it should be all good.
There are adapters available that will adapt that wedge mount to a Ram twist off mount:The only problem I see is to find a way to mount the mirror. Hopefully I can open the factory mirror I have now and the gentex and swap mounts like you said and posted a picture on here a couple of years ago.
Thanks. I will take a look.There are adapters available that will adapt that wedge mount to a Ram twist off mount:
Rear View Mirror FOUR Metal Bracket Adapters with Universal Mirror Mou
Master Tailgaters Rear View Mirror FOUR Metal Bracket Adapters with Universal Mirror Mounting Button Base | Compatible with Volkswagen, Audi, Dodge, Ford, Honda Master Tailgaters, based out of Los Angeles, CA, is dedicated to providing the best quality parts.Our bracket adapters are manufactured...www.mastertailgaters.com
Thanks for the picLook at the LH rear lower outside of the cab, between the bed, and see if you have a cable connection as shown in in red on the photo attached.
Also attached is photo of plug for the digital camera connection at the bumper.
Not sure. I want to install the mirror and get it working with the gentex camera. Then order the 3rd brake light. Someone on here said it probably won’t work because Rams mirror camera is digital and gentex is analog. Plus I live in Canada and everything is so expensive.Just out of curiosity, does the gentex mirror work with the mopar camera in the third brake light?
Hey. I put 2 taps on the orange and red 12v power wire at the same time. Tested the with the volt meter and had 12 volts and mirror still didn’t turn on. I wasn’t sure if you can put two taps on the same wire. I tied one at a time and nothing. Very lost maybe the ground is not on right or a blew a fuse but I have power when the ignition is one. Tested it with the volt meter. So if fuse was blown probably wouldn’t get any volts. Feel very defeated.That guide is a bit odd
If it’s not working then maybe try both switched ignition wires one at a time and if that don’t work then tie them together ?
