Digital Rear View Mirror
Hey bud yeah what year is your ram
Hey. I was wondering if the Gentex GENFDM3LN rear view mirror with display will work in my 2026 Ram 2500 rebel? I want to get one. I just want a a mirror with a display that’s like oem. I bought a wolfbox mirror but haven’t installed it. Thing is big. Has anyone tried the gentex? Any info would be great. Thanks.
I called the Gentex support and they said they did not have anything that would work for the rams. that was a couple months back.
Ironic, since Gentex actually makes the digital rear view mirror that Ram 1500 trucks use.
So you mentioned the ram 1500 may use the Gentex. Ram went with the magna clear view system on the ram 2500 and 3500 23-26 trucks. Interesting.
Yes, for the 23-26 models, Ram introduced the Magna, which is the 3.0 digital rear view mirror.
Well that sucks. I was about to buy one. I thought because it has its own camera I could just install the mirror, give it power and use the camera that comes with it that it would work. I seen others install it in other vehicles and it worked.
That’s all it is, and that one should work in any vehicle. As long as you can come up with a way to mount the camera. Also, looks like it’s set up with a wedge mount, so you’ll need a wedge-to-twist off mount adapter, and it should be all good.
Thanks for the reply. I think I am going to bite the bullet and buy it. I live in Toronto, Canada so it’s going to take a couple of weeks for it to come to me. See what happens I guess. I can mount the camera with double sided tape at the rear window. The only problem I see is to find a way to mount the mirror. Hopefully I can open the factory mirror I have now and the gentex and swap mounts like you said and posted a picture on here a couple of years ago.
There are adapters available that will adapt that wedge mount to a Ram twist off mount:
Thanks. I will take a look.
I wonder if the gentex mirror would work with the oem camera in the 3rd brake light. Or I wonder if I can fit the gentex camera where the oem camera is installed. That would be clean.
