Crusty old shellback
Well, hit another little snag. The screw cap for the rubber pill where you stick a needle in to charge them is a 5/16 24 thread. The schrader valve kit they have is 5/16 34.
So now I'm on the hunt for a high pressure stainless steel 5/16 24 schrader valve. Found one at a different shop than where I'm getting all the other supplies, poly performance. Asked Pol P if they had any of the correct valves so I can do a 1 stop shopping. Rather do schrader valves than the rubber pill as the special needle set up can be expensive.
