Crusty old shellback
No staples. That's the siping groves in the rubber. There for better traction in snow and ice.
If you got the driver side done then the passenger side should be a cake walk, by the looks of it. Nice job.Caviat here.
I'm just a shade tree mechanic of 50 years. I've built everything on a vehicle except a diesel engine and a automatic transmission. Other than that, I've built all of the other parts on them from custom bikes, blown hotrods, and off road toys. So I'm comfortable with wrenches.
Got the driver's side done.
The Good:
All 8 plugs replaced
Didn't break or damage any of the coil packs.
The Bad.
Had to remove the inner fender well and fender flare to access the rear 3 cylinders. Broke a few clips in doing so.
Lots of cussing going on.
2nd and 4th cylinders from the front are the worse to get out. 3rd not much better. Just not a lot of room to work.
The Ugly.
My arms look like I was in a cat fight. Cuts, scrapes, skin missing from my elbows to the back of my hands. No real way to avoid it.
Knees, back and chest are sore. Lots of motrin. Spent a lot of time on my knees, leaning over the hub pressing into my stomach and chest.
There is very little room to work. Sparkplug holes are deep. I got lucky as on the first plug, I had put a 3 inch extension on the plug socket. Dropped it in the hole and the tip of the extension was barley showing.
Some holes I had socket, 3" extension and universal attached. Others I had to swap the position of the extension and universal. Some plugs I could put longer extensions onto that set up and use my air ratchet. Others I could only get a ratchet wrench on. Lots of threads on the plugs.
I only had 1 universal. A second one may have helped to make the job a little easier.
Also I used 2 different spark plug sockets. 1 with the rubber "gripper" in it to hold the plug, the other without.
First few plugs, it was a bitch getting the holder plug off once the plug was in.if you can find a magnetic socket that will hold the plug good while I stalling it, that will work better. Use the gripper socket for removal though
So with pulling the bracket, inner fender well, fender flare, R&R the 8 plugs and reinstalling the bracket, I'm at 4+ hours.
Still need to reinstall the inner fender and fender flare.
I'll tackle the passenger side next.
Ain't no way anyone could get it done in 2.7 hours the book says.
Plus 40k miles in six months that is some traveling.Well just checked my notes
Put the shocks on in June with 62K miles on the truck
I've now got 104K miles on it.
So yea, 40K and they are done. I'll see what CJC says. If they won't rebuild/replace them, then I'm going with Bilstein 5100s.
