Crusty old shellback
Seems like the shaft of your rear shocks are exposed to gravel being down low like that.
Wow, was really hoping it would all work for you. I have the King 2.5 from Carli, I would like to rebuild them myself, when the time comes...Well screw Fox and their shocks and special recharging set up
Just called summit and they have the Bilstein 5100s in stock at the local warehouse. So driving over there to pick up a new set of shocks
That's the part that pisses me off the most. Several email back and forth about schrader valves and the rubber pucks. Never mentioned to me that these shocks use something different.Like they Didn't know when you spoke with them.
I've rebuilt remote resi king shocks before. It's just a bunch of rubber o rings. Just take a good look at the shocks to see how you have to charge them. Could just be a schrader valve, which is the easiest wayWow, was really hoping it would all work for you. I have the King 2.5 from Carli, I would like to rebuild them myself, when the time comes...
The reservoirs have a cap on a schrader valve on my shocks... thanksI've rebuilt remote resi king shocks before. It's just a bunch of rubber o rings. Just take a good look at the shocks to see how you have to charge them. Could just be a schrader valve, which is the easiest way
Simple and easy then. Just ask king what the spec is for setting the floating piston in the resi.The reservoirs have a cap on a schrader valve on my shocks... thanks
