Winch controller cover keeps falling off.
Etoimos
Aug 5, 2021
Colorado
Is anyone else having problem with the winch controller plug coming loose while you are driving and interfering with the front sensor? Is there a fix for this?
Wobly
Mar 19, 2021
Colorado Springs, CO
I have never had my controller cover come loose. I even have a healthy coating of dielectric grease on my plug and it still stays where it belongs.
wills22PW
Jul 17, 2022
I have this exact problem. The cover has been coming loose since the truck was new but I don’t recall the sensor issue happening until about 6 months after I bought the truck. I never put the 2 together until this post. Makes the most sense though. I was planning on pulling all the sensors and cleaning the connectors and de-coupler rings soon just to see if it helps. The fault I get is front park sense unavailable-wipe sensors or something to that effect.
Etoimos
Aug 5, 2021
Colorado
That is the same fault I get. It is the cover swinging down in front of the sensor. I may see if some type of putty in the cover recesses will help hold it in there.
jetrinka
Jun 11, 2021
I've got some dielectric grease around mine to help keep it in/seal moisture out as best as possible. Never had a problem with it coming out though.
Kauffmj1
Sep 4, 2022
I've had it happen as well. I did the grease trick everyone else mentioned. Just enough to give that cover a little more sticking power.
Etoimos
Aug 5, 2021
Colorado
Thanks everyone, I'll try the dielectric grease and see how it goes.
