Wheel offset help
KimWar1911
Mar 5, 2022
I have a 2018 3500 that is pretty much stock, other than 295/70r18 Cooper ST Maxx tires on the stock rims. I am looking to upgrade the stance a bit with aftermarket wheels but don’t want to get too wide or aggressive. If I am doing the math correctly if I go with a zero offset the wheels/tires will be about 1.5” wider than stock? Plus 18 would be narrower than that, and minus 12 would stick way out.
Does anyone else run that tire size with aftermarket wheels? If so can anyone help me with pics of your trucks? Thanks
Crusty old shellback
Apr 10, 2021
First you need to figure out what your stock rim width is along with the offset/back spacing.
Then look at those same specs on the new rim you want. That will tell you how much it will stick in or out or be the same. Some rims come in different widths/offsets/backspacing. Others are just a one size fits all approach.
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
I would highly suggest looking through the gallery at the customwheeloffset site (no affiliation, I jut appreciate the visibility it allows). Anything you see from 2014-2022 for a 2500 or 3500 will result in the same look on your truck and you can filter for tire sizes, wheel sizes, and much more.
But as to the specific questions about +18/0/-12, the answers highly depend on what width wheel you're looking at as those offsets would look and fit very differently for a 8" vs 9" vs 10" wide wheel.
KimWar1911
Mar 5, 2022
Thanks a lot for your responses guys, and to clarify the rims will be 9”. I have been on custom offsets site but didn’t look at the newer trucks as examples, only my vintage. That is great info and I will get on there more for examples. Thanks again
