What is normal oil consumption?
Cummingeddon
Feb 12, 2020
Can anyone give some input on what you see as normal oil consumption? I've got what seems to be a new issue with burning oil. My 2019 3500 HO has about 52k miles on it, with about 18k miles of that pretty heavy towing (20k lbs fifth wheel). I just changed the oil a couple of weeks ago and seem to have burned through about 1 quart of oil over the last 1,400 miles of towing in the last week. It was driving east on I-84/80 from the coast, so there were some decent grades along the way, but nothing the truck hasn't seen before, like in Colorado. I usually use the T6 5W-40, but had to put in 10W-30 in the recent change because that's all I could get my hands on in the area. No noticeable soot around the end of the exhaust.
Firebird
Sep 24, 2020
Normal consumption? Zero
To date, I've never had a Cummins use oil
Should not use oil at all but yea the 10w30 is way to light for a diesel idc what ram says so that could be your issue
BAT3500
Nov 29, 2020
How many miles were on the oil before changing? It may be just a sign of dirty oil.
My last ram used/lost some oil in a relatively short time when i apparently extended the oil change interval a little too far. Dash gauge said i had oil life left and i was also going by the oil analysis from the previous oil change but something changed during that one oil cycle. Never used oil again while i owned the truck
He said 1400 miles if i am reading it correctly
Cummingeddon
Feb 12, 2020
There were maybe a few hundred around-town, non-towing miles on the oil before we started the trip east with the trailer.
Aketay
Apr 5, 2020
Oil is cheap, mine has burned a quart every 5000 to 7000 miles since it was new. At 339,000 now and the exhaust pipe is still clean.
DontSlamMyRam
Dec 30, 2019
Mine sucked down over a gallon of T6 in appx 7kmi. I've checked the level a few times since last OC and seems fine. While it's not the end of the world. It is one more thing to dislike about my '19. Wish there was another option that I found appealing to own.
Neither my 05 or 18 burned any oil.
Mar 9, 2020
When i change my oil i can always fill the gallon jugs back up with the used engine oil. It always seems like there is plenty of room at the top of each jug. Now if you add whatever s left in the filter maybe its not quite as much as it seems?
