What do you guys use the 110v outlet for?
jeffn
Nov 1, 2020
Well it really depends on what you are using if you need 6v then yes usb works if you need 110v then the ac outlet works but there are plenty of 12V accessory's that run off the 12V plug they are not relics. I use my 12V plugs often enough
12v electrical systems are a limiting factor. You will see these getting replaced by 48v systems in the model years to come.
Mobrules
Dec 29, 2021
I use mine to charge ecoflow battery. Takes about 5 hours but cold nights the ecoflow runs heated blanket. Having the 400 watt outlet is very useful. Currently doing a trip around the country.
12V is not limiting besides with the electric vehicle mandates it will all be 300V next lol. 24V/48V systems have been used in equipment and some heavy trucks in the past it is not anything new but i doubt we will see it in the automotive industry its nothing that would benefit the automotive industry in an extreme way
CortexM0
Jul 15, 2022
I mostly use mine to power a Starlink in-motion system. Having fast enough internet to hop onto a video call (even hours from cell service) completely changed my vacation last summer.
Screenshot 2023-12-31 at 9.51.48 PM.pngScreenshot 2023-12-31 at 9.56.13 PM.png
jeffn
Nov 1, 2020
It is limiting for well-understood reasons. Drive by wire systems, electronic suspensions, mild hybrid systems, and redesigning subsystems (AC, power steering, coolant pumps) to take them off the engine requires wiring harnesses that significantly increase weight and volume. The higher voltages reduce resistive losses. 48v is optimal while staying below the steep safety and performance requirements when you go above 60v.
gimmie11s
Mar 30, 2021
Haven't used mine. Hell, I don't even know if the outlet is alive when the truck is off or if the truck must be running.
Guess I have something to do today ha
The in cab one is off when the truck is off
Jack M
Aug 9, 2021
I have used the outlet in the box twice.
It will work with a battery charger.
It will not run my shop vac. Not much use as far as I am concerned.
