What are the major part differences between the 2019 3500 SRW and DRW
Gray Ghost
Oct 27, 2019
Does anyone know what the drivetrain part differences are between a 2019 3500 SRW and a DRW? I have all the towing options from the factory, not HO, 4.10. A big piece of the towing and payload weight increase are the extra tire carrying capacity but I was just wondering...
What about the major parts (are rear ends the same? I would guess the driveshafts on forward to the engine would be the same, are brakes the same?)
Thanks!
GeneralClortho
Jan 26, 2021
DRW stands for Dual Rear Wheels, so a dually.
SRW stands for single rear wheels.
Was that the question?
RV_Goose
Aug 14, 2020
The OP is asking if anyone know the difference in parts, like axles, springs, etc between the DRW and SRW. I suppose he wants to know why there is a 1500-3000 payload difference between them.
The only difference is the hubs to make the duals fit i believe they use the same axle housing for both the srw and drw the big increase is having more tires to carry the load as the srw is topped out by the tires carrying capacity...
Hubs different and because of this, the axle tubes are necked down on the SRW.
DRW is 4" axle tube size all the way.
Both are 12" AAM ring gear.
Pretty sure the DRW also has slightly larger outside diameter rotors/calipers but I believe that may be on the Max tow (4.1) package only even the the hubs are larger?? I think someone here compared the two at one time.
I thought the 4” was used on the srw as well that sucks for the srw guys
lowfidelity
Dec 13, 2020
I could be mistaken but I thought I read the SO has a 11.5” AAM. Trying to see where I read that...
lowfidelity
Dec 13, 2020
Yep, based on what I see on Ram’s build, I’m fairly certain the 12” AAM is reserved for HO configurations (not sure on DRW)
