Wandering cruise control
jnma1234
Feb 20, 2023
My 2014 6.4 l will hold a steady speed until I go up and incline, then it drops two to three miles an hour and suddenly takes off. I wondered if anybody else had this problem.
Well yea thats how cruise works it is likely downshifting when it “takes off” and not a problem
jnma1234
Feb 20, 2023
Yeah, I understand that's how cruise works, but in every other vehicle I've owned, it doesn't drop three miles an hour before it reacts.
Have your other vehicles been 7-8k lbs you are not driving a sportscar lol
jnma1234
Feb 20, 2023
Yes I have. As a matter of fact one of my other vehicles is 80,000 lb, and that never lags.
racer4
Jun 22, 2022
The weight of the truck does not affect how fast the cruise control reacts.
And when it does react, there is plenty of power to handle the weight.
My 2007 GMC 2500 Duramax cruise control worked way better than my 2016 Ram 3500 6.7L.
It reacted sooner, but did not over react. It would increase the turbo output first, if that didn't maintain speed, then it would downshift. The Ram downshifts more often.
The GMC cruise behaved much smarter than the Ram cruise control.
jnma1234
Feb 20, 2023
It behaved much smarter than the Ram cruise control.
So, do you know is there a fix to make the cruise control more sensitive, or is that just the way Dodge Ram 2500's are?
racer4
Jun 22, 2022
In my experience, that's how they are.
I have a 2023 Ram 3500 on order, at the dealer, on recall sales hold.
I hope it will be better, but probably not.
The weight of a vehicle 100% changes things. your non emissions duramax is much different than the emissions setup CTD and likely unlocked the torque converter or you “increasing turbo output” and not being a VGT turbo setup the increased rpm brought the turbo speed up more than the VGT cummins does. My 05 cummins was better for cruise than my 19 was before my delete now the cruise is much better its just how it is.
His is a gas truck the only way it can gain speed is to unlock then downshift and with a heavy truck you lose speed faster than a car does. Hence the issue he has
If tuned it will be better but if stock it wont be the tq management and the VGT make them take more time to build the power unlike the old trucks
racer4
Jun 22, 2022
Simply put:
I was pleasantly surprised at how well the 2007 GMC cruise worked, compared to previous experience.
I was disappointed at how well the 2016 Ram cruise worked, compared to the 2007 GMC 2500. It was a step backward.
Simply put:
Comparing apples to oranges though due to the emissions systems, safety systems and different turbo setups the old stuff was better there is no doubt about that. That one reason i keep my 01 3500 around lol.
