Have your other vehicles been 7-8k lbs you are not driving a sportscar lolYeah, I understand that's how cruise works, but in every other vehicle I've owned, it doesn't drop three miles an hour before it reacts.
The weight of the truck does not affect how fast the cruise control reacts.Have your other vehicles been 7-8k lbs you are not driving a sportscar lol
So, do you know is there a fix to make the cruise control more sensitive, or is that just the way Dodge Ram 2500's are?The weight of the truck does not affect how fast the cruise control reacts.
My 2007 GMC 2500 Duramax cruise control worked way better than my 2016 Ram 3500 6.7L.
It reacted sooner, but did not over react. It would increase the turbo output first, if that didn't maintain speed, then it would downshift.
It behaved much smarter than the Ram cruise control.
The weight of a vehicle 100% changes things. your non emissions duramax is much different than the emissions setup CTD and likely unlocked the torque converter or you “increasing turbo output” and not being a VGT turbo setup the increased rpm brought the turbo speed up more than the VGT cummins does. My 05 cummins was better for cruise than my 19 was before my delete now the cruise is much better its just how it is.The weight of the truck does not affect how fast the cruise control reacts.
If tuned it will be better but if stock it wont be the tq management and the VGT make them take more time to build the power unlike the old trucksIn my experience, that's how they are.
I have a 2023 Ram 3500 on order, at the dealer, on recall sales hold.
I hope it will be better, but probably not.
Simply put:The weight of a vehicle 100% changes things. your non emissions duramax is much different than the emissions setup CTD and likely unlocked the torque converter or you “increasing turbo output” and not being a VGT turbo setup the increased rpm brought the turbo speed up more than the VGT cummins does. My 05 cummins was better for cruise than my 19 was before my delete now the cruise is much better its just how it is.
His is a gas truck the only way it can gain speed is to unlock then downshift and with a heavy truck you lose speed faster than a car does. Hence the issue he has
Comparing apples to oranges though due to the emissions systems, safety systems and different turbo setups the old stuff was better there is no doubt about that. That one reason i keep my 01 3500 around lol.Simply put:
I was pleasantly surprised at how well the 2007 GMC cruise worked, compared to previous experience.
I was disappointed at how well the 2016 Ram cruise worked, compared to the 2007 GMC 2500. It was a step backward.
