Uneducated in the ways of the custom wheel - Help
StrayCat
Sep 26, 2022
Hi folks, I just took deliver of mine RAM 2500 Diesel. and I plan to get some custom wheels and tires for it (same side as stock, nothing radical). I dont want wheels sticking out wide, I just want the stock stance, and of course no rubbing cutting (stock tire size will be going on - just not the Firestone on/off road it cam with, theyre useless IMHO)
My stock rims are 18x8, most aftermarket wheels in 18" size are 18x9 - this means (I think) that I need to consider what Offset I need, and I have no clue how to determine what offset to order for what wheel (im sure different wheels need different offsets for my truck?).
some wheels come with 00 offset, some with +18 offset and Im clueless as to what I should buy
Is there a way to know ?. These things are too expensive to make a mess of ordering the wrong wheels.
Delar parts guy said I needed +18 offset to compensate for the 9" wide rim, while some wheels only show a 00 offset for my truck
Im lost
appreciate any advice and insight
Jnrcarson
Nov 28, 2021
You can go to a site called custom offsets and put in parameters and see actual builds and what the truck looks like with each offset, etc. helped me choose as I wanted the same as you did. I ended up with 18x9 +18 offset. Tires like out a little but can’t help it going to 35’s.
The stocks are +57 offset so if you want wheels with similar stance thats what you are looking for. The lower the number the further they will stick out in MM
This tool will help you with figuring out the tire poke from different wheels
StrayCat
Sep 26, 2022
Thanks
I was told the offset is dependent on the rim width.
The stock rims are 8” wide
Most aftermarket are 9”.
Dealer told me I need a +18 Offset But IDK
Most of the RAMS on the customoffsets.com are +18 and stick out a little bit.
Not many out there with a bigger positive offset that I can find.
I’ll keep looking
Thanks for the reply
Dinky503
Jan 29, 2023
Hillsboro Oregon
Thanks
I’ll keep looking
CJC has a method racing exclusive 17in wheel with a +25 offset. made the tires flush to the fender with no Flares. I had them on my 3500 but not much tire selection for weight rating. A 2500 you should be fine with those wheels.
Jimmy Dean
Apr 26, 2021
NJ
For reference, this is leveled with 37s. You can fit 35s with no level and these wheels. If you have fender flares, they won’t stick out with a 12.50 inch tire.
Method 305s 20x9 +20 offset I believe
Tank for scale
StrayCat
Sep 26, 2022
Cheers, I’ll see if any of our suppliers here in northern Canada can get them.
There is my other issue. Seems we have more limited supply than the USA, a lot of stuff that I like, I can not get and shipping cost from the USA is madness.
I’m sure I’ll find something.
Jimmy Dean
Apr 26, 2021
NJ
I ordered from Custom Offsets, they were pretty good to work with.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Plenty of pics of members trucks here with different wheels on them to use as examples. Custom offset website is a great resource, as stated.
Pick a “stance” you like and go with it.
I knew I wanted to add flares to mine so I went a tiny bit wider than stock. Personally don’t like the look of stock wheels with flares added on (common on tundras, seems like) just depends on what you like
I’m in Canada , so shipping from the USA costs as much as the wheels. I wish they were local.
There are many canadian vendors that can get you better price check out Tdotperformance.com or other canadian vendors sometimes worth calling for ease
StrayCat
Sep 26, 2022
Yea, thanks , I’m hoping a local pace can get me what I want so I can save shipping costs. I know what I want now, so that’s half the battle.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Ok, new one for me, what is “ scrub radius” ?
Draw an imaginary line through your steering pivot points (ball joints) and an imaginary line through the center of your tire. In a perfect world they would intersect at the ground. Adding scrub radius adds steering weight. As you go taller you can go wider and keep the same scrub radius
