Thanks. I read the TSB. No way to correct without the dealer doing it?search this on interwebs:
TSB: S2108000015 - REV. H
Release Date: March 2022
Symptom/Vehicle Issue: Uconnect Box Requires Service Message
Hello Downsc123,Thanks. I read the TSB. No way to correct without the dealer doing it?
I have had this issue before. Take your truck to any Ram Dealership service department and have them check it out. This is a known issue and it is covered under warranty.I have been getting Uconnect Box errors periodically but nothing seems to be wrong (everything works fine except for the annoying error). Anyone know the fix for this?
C16,Does the dealer actually fixed anything if there are no error codes, seems like it’s supposed to get a certificate but that should happen without a dealer visit. This comes and goes on my 2022 PW. It’s annoying, hoping a software update fixes this error message
Can ram cares definitely state if a dealer visit is required to get rid of the message or will a software update remove this. Waste of time to take it in for this simple error message.
Hello CI6,argh this is frustrating, took it to the dealer for this and recalls, diagnosed with a bad telematics module.. had to wait for the part, today took it in for the telematics module replacement..
guess what pops up on the drive home. same error message.. only difference now is that SOS and Call button LEDs do not light up red, but same error code.. guess another dealer visit
Hi dub96,My dealer said there is nothing you can do until an OTA update comes out!
Point being, if you don’t let us know what version you are on, then nobody here can help you. You might as well just start a private conversation with ramcares, and see how far you get with that.Not sure, I had a picture of it, I must have deleted it... Point is, I shouldn't have to care, my 80K truck should work!
