I don't have any pictures of the trucks in action, but you can see the data yourself. For whatever reason Ford doesn't have their turning radius or diameter listed on any of the spec sheets for 2023, at least that I've been able to find, and nothing on their website.
I was able to pull the data on the 2023 models from C&D.
2023 Ram 3500 Laramie, 4WD, CC SB (
link to C&D)
Turning Diameter: 47.7'
Turning Radius: 23.85' (Ram lists as 23.8',
link)
2023 Ford F-350 Lariat, 4WD, CC SB (
link to C&D)
Turning Diameter: 53'
Turning Radius: 26.5'
Difference between two "identical" models: 2.65'. So if anything, I was actually giving the the Ford about 2" less than it's listed. Ford also seems to have some different numbers listed online in other sites (the same number and a sometimes larger number), which I believe may be due to wheel offset on certain models, but I assume that may be similar to the Ram, so I used the smallest number I could find for the Ford.
Keep in mind that the Ram 3500 has a wheelbase of 149.5' (
according to Ram) and the Ford F-350 has a wheelbase of 164.1' (
according to Ford) so that is a difference of 14.6" (~1.22'). Wheelbase has a pretty large impact on turning radius along with the front axle obviously.
If you are able to find additional information that states otherwise please share, again this is only data I've been able to pull not from Ford, so I'm willing (and somewhat hopeful) I'm wrong here.
