I have a Thuren 2.5 suspension on my truck and I am experiencing unsettled "rocking" side to side when i hit bumps. I don't know if this is what people refer to as "death wobble" - I always assumed that was wobble in the steering system, this feels more like it is concentrated in the rear end, although that feeling is probably somewhat subjective. This is a low speed, underdamped feeling, not the classic "rough ride" that people sometimes complain about. The issue has seemed to appear in the last few weeks, seems far worse than when it was newly installed. It happens unloaded, I hauled a relatively heavy motorcycle in the bed of the truck last week and that made the rocking way worse - having weight up high center of gravity. I have done a cursory check - none of the shocks are leaking and all of the sway bar links are still attached. Anyone else experience a similar issue, or have any ideas of where to start looking for a problem? Here are the details of the kit:
2500 truck, CTD, coil springs no air.
Truck has 50k Miles on it, kit was installed at 10k miles
King 2.5 Shocks, Leveling length
Front shock axle mounts replaced with Carli Weld-on brackets (one of the factory mounts failed snapped off last winter)
Thuren Springs F/R
Thuren Active rate sway bar - front
Thuren sway bar links F/R
Thuren Trackbar
Stock steering damper
Tires - 37x12.5R17 Kenda Klever Pressure 40F/40R
Haven't had a recent alignment but no abnormal wear. this doesn't feel like an alignment issue but I could be wrong
Thuren Springs F/R
Thuren Trackbar
