is truck might be a victim of the decontenting from the Rona chip shortage. All the "Level B" instead of "Level 2" (normal) type stuff going on.
I dunno. If it has the 360 view that you posted, it physically has the cameras and should be able to broadcast them back. I'm with Brutal it looks like a glitch didn't add the feature to the BCM.
Whatever the case may be, in Ram’s eyes, your truck is not supposed to have trailer reverse guidance. It’s not listed on the build sheet for your VIN (it would be a line item right above “Integrated Voice Command w/Bluetooth”). Jscan doesn’t currently have the setting you need. Once you get AlfaOBD up and running, just change VehConfig 8: Trailer Reverse Guidance to YES, and you’ll be all set.I can’t get Alpha OBD to work with the three connectors I have. I will have to order the right ones and the bypass harness. I did get JScan to work but I couldn’t figure out the BCM download.
I agree it's confusing. On my Laramie, trailer reverse guidance was part of the trailer towing technology group.The B&P package stuff looks very confusing...
It's shown on TTG surround view:
Yet, it's listed as you say, under Level 1 group
It is literally just a different view with surround view and directly related to towing, so I don't know it would not be included with trailer technology.
If I was OP, I would try to get the dealer to just add the option code.
Sent from my SM-G988U1 using Tapatalk
