Is it capped?Definitely not there. The plug is still there, just with nothing hooked to it.
Does anyone have the part # for the shorter valve stems?Shorter valve stem vs original length. Will install this weekend.
The 12 pin connector has nothing to do with the TTPMS feature, but if your truck came with the option and you have the sensors, you’re good to go.From what I understand, everthing is enabled in a 22 DJ with the 12 pin connector, add trailer sensors and go, correct?
If you have the module in place and the sensors, you’re good to go.It came with the 360 camera and has the module behind the plate.
Just to clarify for other 2022 owners that come across this, just because 360 and 12 pin is present, doesn’t necessarily mean TTPMS is there. NORMALLY, the tow tech package includes TTPMS, but for 2022, at some point they changed that package to “B”, that doesn’t include TTPMS. Having the 12 pin and 360 on a 2022 is a byproduct of having the tow tech package, but won’t always mean TTPMS is. You’d have to physically verify, or check the equipment listing to know for sure.
In your case, it seems you got in on the tow tech package before they stripped TTPMS from it.
If it’s on the equipment listing, then you should have the feature and the sensors should have come with the truck.So in order to verify whether or not its on the truck with above packages would be A) check the obvious place behind plate. B) pull up body build sheet from FCA? If the module is there and equipment build sheet says its there all a person needs to do in theory is get said shrader sensors and be happy?
Anyone have more than one trailer they hook up too, like boat trailer with sensor, and also maybe a fifth wheel or other trailer with another set of sensors they pull separately and the truck reads each trailer sensors when connected?
so if i have the "Towing Technology Group B" on the build sheet . i do not have the ttpms ?If you have the module in place and the sensors, you’re good to go.
I don’t keep up with what options are included in what packages anymore, since they seem to constantly be changing them this year. If you have it, it will specifically be listed on your equipment listing under optional equipment.so if i have the "Towing Technology Group B" on the build sheet . i do not have the ttpms ?
Did the dealer screw up the order? Mine has everything except the sensors and I didn't order it. I have since gotten the sensore
