- Joined
- Oct 5, 2021
9/10 problems on this forum are Cummins problems. Don’t end up with dealership problems if you aren’t at the dealership.
More Cummins HD’s than Hemi’s means more problems.
Good points. OP, hope you get your truck fixed soon.
I dont envy people who are in your position. However, if I were needing a diesel Id probably go to a 4th Gen and deal with the issues they have as they dont seem to be eating engines/cams/lifters. I had a 13 G56 truck and it was awesome. I simply didnt need a diesel so got rid of it.i used to have a 1500 and loved that truck. Needed a diesel for work to haul things, and now were going to get a travel trailer probably around 32'. I would love to be able to go back to a gas truck but it doesn't make sense. There are a lot of hills around here and towing weight with gas isn't fun.
Yeah I hope it gets fixed to. I don't know if I am keeping it or trading it in. I have a couple sales people working on numbers now. Parts of me want to keep it to just tell the dealer look I told you so. Either way it could cost me $20k, I will definitely keep everyone posted on the matter.
I hear you! They're tough to find clean. When I bought my 19 limited, there was a 2018 3500 with 18k miles on it. I almost bought it instead. They're out there!Finding a 4th gen in my area that is not all clapped out is pretty hard lol.
Quick search, theres a low mileage laramie in WashingtonFinding a 4th gen in my area that is not all clapped out is pretty hard lol.
Highly recommend using the basic or advanced oil analysis kits that Cummins sells. They’re less than $20 and they utilize Polaris Laboratories. You’ll get excellent analysis and a very in depth explanation of the results.Oil level is documented with the dealer and I need to return after 500 to 1000 miles. We will pull oil sample then. I'll probably have my shop do it next week as well.
How does excessive regens add fuel to the oil?
I’ve been tracking the frequent regeneration issue for a while now. 60%+ of the trucks reporting frequent regeneration issues are 2022’s. Your engine oil was overfull specifically because of the frequent regeneration. I’ve seen this over and over. If you’re not someone who actively monitors their regeneration cycles, the truck will do it every 100 miles or less in some scenarios. That frequency is sometimes just enough that it doesn’t trip DTC P2459, but plenty often to cause severe fuel dilution in the crankcase. I had two owners send me their oil analysis reports recently (both are having frequent regeneration issues) and both had high levels of fuel dilution. One was about 6% fuel dilution in 3,000 miles. If left unchecked regen frequency can spiral out of control. It will increase oil level due to excessive fuel, then this causes the CCV filter to become saturated because excessive amounts of oil vapor get drawn into the ventilation system. Ultimately it’ll pool in the intake of the turbocharger and be pressed into the intake air stream where it further compounds the regen frequency problem. Ram engineering (STAR) is fully aware that they have a problem with these regen frequency issues, especially in 2022 trucks. I can provide you with more information if you’d like, or you can check out the running threads I have on this over in the powertrain section.
When the truck goes into an active regeneration mode, the engine’s fuel injectors are used to supply diesel fuel into the exhaust system for the purpose of increasing the temperature inside the DPF. The injectors are triggered during the exhaust stroke and the fuel is shot into the cylinders on a non-combustion stroke. The cylinders push the fuel out of the cylinder via the exhaust valve and into the downstream exhaust flow. Some of the fuel that is injected into each cylinder ends up passing down through the cylinders and into the crankcase sump. It is unavoidable. Under normal operation and use, active regeneration should only really occur every 24 hours (if the truck is being worked hard enough to keep soot loading down in the DPF). Typically this means that the average truck should go about 1,000 miles and 24 engine hours between regeneration cycles. In that scenario, the truck will only see 10-15 regeneration cycles total within a given oil change interval. Fuel dilution in this case, would be kept to minimum acceptable level. When you have a truck that’s regenerating too frequently, this fuel dilution problem can increase rapidly and get out of hand quickly. Take for instance a truck that’s malfunctioning and regenerating every 100 miles. This means it’s regenerating ten times more often than a truck that’s running correctly. Ten times the number of regenerations also means ten times the amount of residual fuel being passed into the engine oil. This can raise the engine oil level in the crankcase sump above its normal maximum level. Which in turn causes additional issues with excessive oil / fuel vapor being drawn into the ccv filter system and ultimately passed to the intake air stream via the turbocharger.How does excessive regens add fuel to the oil?
And Ram/FCA/Stellantis with all of the crack engineers they feel they can afford have absolutely no idea of what the problem is. And despite their exaltations, I don't think Ram cares one tiny bit.When the truck goes into an active regeneration mode, the engine’s fuel injectors are used to supply diesel fuel into the exhaust system for the purpose of increasing the temperature inside the DPF. The injectors are triggered during the exhaust stroke and the fuel is shot into the cylinders on a non-combustion stroke. The cylinders push the fuel out of the cylinder via the exhaust valve and into the downstream exhaust flow. Some of the fuel that is injected into each cylinder ends up passing down through the cylinders and into the crankcase sump. It is unavoidable. Under normal operation and use, active regeneration should only really occur every 24 hours (if the truck is being worked hard enough to keep soot loading down in the DPF). Typically this means that the average truck should go about 1,000 miles and 24 engine hours between regeneration cycles. In that scenario, the truck will only see 10-15 regeneration cycles total within a given oil change interval. Fuel dilution in this case, would be kept to minimum acceptable level. When you have a truck that’s regenerating too frequently, this fuel dilution problem can increase rapidly and get out of hand quickly. Take for instance a truck that’s malfunctioning and regenerating every 100 miles. This means it’s regenerating ten times more often than a truck that’s running correctly. Ten times the number of regenerations also means ten times the amount of residual fuel being passed into the engine oil. This can raise the engine oil level in the crankcase sump above its normal maximum level. Which in turn causes additional issues with excessive oil / fuel vapor being drawn into the ccv filter system and ultimately passed to the intake air stream via the turbocharger.
I think the major issue is that this will never be a problem with a “one size fits all” solution. The level of complexity these trucks have is staggering. There are multiple independent systems that all tie together when it comes to regenerating the DPF. If any one of those subsystems has an issue, the balance gets upset and things start working incorrectly. Add to this variables in each trucks daily duty cycle, as well as the type of operator the truck has, and you have a very complicated issue that requires significant amounts of time to digest, dissect, and diagnose. It’s a snowball of complexity, enlarged by lack of experienced technicians, made further larger by dealerships that are under time crunches and out of service deadlines, and what you end up with is a conundrum.And Ram/FCA/Stellantis with all of the crack engineers they feel they can afford have absolutely know idea of what the problem is. And despite their exaltations, I don't think Ram cares one tiny bit.
