Dinky503
I’ve been tracking the frequent regeneration issue for a while now. 60%+ of the trucks reporting frequent regeneration issues are 2022’s. Your engine oil was overfull specifically because of the frequent regeneration. I’ve seen this over and over. If you’re not someone who actively monitors their regeneration cycles, the truck will do it every 100 miles or less in some scenarios. That frequency is sometimes just enough that it doesn’t trip DTC P2459, but plenty often to cause severe fuel dilution in the crankcase. I had two owners send me their oil analysis reports recently (both are having frequent regeneration issues) and both had high levels of fuel dilution. One was about 6% fuel dilution in 3,000 miles. If left unchecked regen frequency can spiral out of control. It will increase oil level due to excessive fuel, then this causes the CCV filter to become saturated because excessive amounts of oil vapor get drawn into the ventilation system. Ultimately it’ll pool in the intake of the turbocharger and be pressed into the intake air stream where it further compounds the regen frequency problem. Ram engineering (STAR) is fully aware that they have a problem with these regen frequency issues, especially in 2022 trucks. I can provide you with more information if you’d like, or you can check out the running threads I have on this over in the powertrain section.
Thanks I'll take a look at it, i might need it to prove where the fuel is coming from. The extra fuel could toast bearing and other things. Maybe @RamCares could take a look at this too.
