Just finished up my second Titan tank install. I had installed a 50g Titan on my '22 2500 CCSB when I got that and have now installed a 52g on my '24 3500 Mega Cab short bed SRW. Overall it's a very technically easy install, but with cramped working space don't expect to be done in 1-2 hours...unless you have very small hands and very long arms. Depending on the tank there's only 4-6 connections; 3 to the sending unit plus fuel fill and vent tubes
- Both installs took roughly 5 hours from start to finish in a driveway with the truck on jack stands. I'm not including time it took me to syphon the fuel between the two tanks... have a plan for that BTW!
- For the 2500 I syphoned the fuel over before I installed the new tank
- for the 3500 I syphoned after the new tank was installed.
- I preferred doing the install with an empty tank personally.
- In both cases, I think it could be done without lifting the truck, but lifting was helpful in that I could remove the rear driver's side wheel and tire for easier access to the fuel fills AND these tanks are much taller than the stock so it was easier to get them under the truck for the install.
- The most difficult part is disconnecting the connections. Use your cell phone camera or whatever you might have to take photos of all the connections and get the lay of the land. It'll be handy when you're trying to disconnect/reconnect them all blindly.
- It's important to understand how each of the disconnects work too! watch some videos online to see how their locking mechanisms work.
- the 2500 was definitely a harder install due to the lack of the space, but not significantly.
- In both cases I could NOT get the fuel sending unit locking ring to seat property with the Titan provided o-ring and used the factory o-ring instead. With the Titan o-ring the locking ring was very very tight and I was concerned that I was going to break something trying to turn the damn thing -OR- that I was going to over-adjust if I tried to modify the locking ring to make it easier to turn. The factory o-ring was plenty tight, to the point that it was only slightly easier to install, and I've got zero worries that'll it'll be fine.
- I used a hydraulic cart to lower the old tank and lift the new tank in place. Wish I had had one when I did the 2500.
- Dry fit the new tank straps while there's no tank in place! the 3500 went great, but one of the straps that came for the 2500 required a little grinding before it'd fit into it's mounting bracket on the frame.
- I haven't updated my fuel capacity in the computer with alfaobd. Had started to go down that road, but the tank reads right once those extra gallons are consumed and milage updates accordingly... I found I wasn't looking at my fuel gauge with any interest until it showed half or less anyway and I reset the trip each time I refill, so I had a good sense of how far I could go on a full tank. Just never found myself wishing I had made the adjustment and so never pursued it.
- On the MCSB there's a vent tube from the forward(short) end to the back(tall) end of the tank. I assume it's there just to help get any air trapped in the front of the tank back to the taller part of the tank to be vented. I pulled the hose off and put a hose clamp on at both ends, just for my own piece of mind. they were reasonably tight on the fittings, but they can be pulled off without any real effort and I had the clamps laying around.
I've read a few posts comparing the Titan and S&B tanks. My bet is that either is a great choice. I wanted to clarify though that the Titan tanks are different between the crew cab short bed and the mega cab (and probably again for the long bed) and some of the feedback isn't applicable to both of them.
- The CCSB tank wraps around the frame a little and so hangs down a bit more. Personally, it took me all of 30 minutes to completely forget it was there. Some folks notice those things and some don't. I AM the type though that notices the .5" of lean in the truck and that the bed is .25" off left to right from the cab and have to make a conscious effort to ignore and accept those things. The tank though, didn't bother me in the least. You can't see it unless you're laying down next to the truck, but even then you appreciate the extra milage and seeing the tank reminds you of all the good times the two of you have had.
- The MCSB tank hangs down more than the stock tanks, but not nearly as much as the CCSB tank and it doesn't wrap around the frame... someone who doesn't know that an aftermarket tank has been installed would never notice it.
- The CCSB does droop a little toward the front and sags a bit between the straps due shape of the thing, but it's only natural and not anywhere near the point that it's concerning.
- The MCSB 52 gallon tank comes with an additional 3rd "strap" (it's really just a bracket) that bolts onto the frame and supports the longer tank. I've only had the tank installed for 2 days now, but filled up I don't see any droop or sag. I won't see any droop, I'm sure; sag between the straps I doubt I'll see, but we'll need some warmer weather before I can be sure
Overall I've been really impressed with the quality of both my Titan tanks and have ZERO complaints. They hold fuel and otherwise keep their mouths shut.
