Tailgate issues
GarnetandBlack21
Aug 30, 2021
Not sure if it's me but the tailgate seems like it's gonna get damaged because it bangs around when I hit a bump. It's extremely loud, think it's because it's so light. Anyone else have this issue and know a fix? Truck has 1800 miles.
If its latched in it should be nice and tight if not i would be going to the dealer
GarnetandBlack21
Aug 30, 2021
I can't see anything that's off. It's really weird! Since it's brand new, something has to be loose somewhere. ☹️
IndyRamMega
Sep 21, 2021
You gotta slam it closed. From the middle, not one side. Try that.
Yup...it's like a car door...if you don't use enough force it stops shy of being flush like a door that didn't latch all the way....learned that after being too gentle the first couple times closing it....
jadmt
Aug 29, 2020
Age
65
Missoula
I don't have to slam mine at least excessively hard. OP do you have a photo or better yet a video showing how it moves? any chance there is something caught in the latching mechanism? when I had mine lineXed they had some over spray on both sides in the latches and that caused some issues but it was easy to clean it out with a pick.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
I wouldn’t say excessively hard. But, you really need to close it like you mean it. And, you certainly cannot close it from one side or the other. At least my tailgate Pretty much has to be closed from the middle with a slam
I’m not saying he doesn’t have an issue, just like to rule out the easy common things first.
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Are you 100% sure it is the tailgate?
I know others have mentioned loose spare tires banging around underneath. Before I tightened my cab mounts I know that sound was horrendous over the right bumps as well. And not on this truck, but on my 4th gen, my track bar worked a bolt half a turn loose, which over speed bumps sounded like the world was ending.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Good point!
Also, hitches have been know to bang around in the receiver over bumps.
