Rockcrawlindude
a rock crawlin’ dude
TDLR:
- easy to install.
- squat busters.
- initial drive they seemed pretty stiff.
- large bumps like speed bumps are stiff.
- after more miles I’m happy with them when unloaded despite occasional hard bumps
- phenomenal towing experience
I decided to try sumo springs as a load helper on my Ram. The main problem is the fact that my truck is “leveled” 1” and when I start towing that makes my truck look nose high. The bulletproof and maintenance free aspect drew me to try these.
So what’s the deal?
Sumo spring SSR-312-47
2019 Ram 2500
Kit weight : 8 lb
Kit contents
Tools needed
7/32” Allen key
16mm loosening tool of choice
Install took about ten minutes, I did not need to jack up the truck or remove the tires. The base bracket replaces the bump stop and reused factory hardware. They include blue locktite. Position the spacer, lock it down, Spin on the sumo spring.
When i went to install the sumo, I just needed a hair more space. So, I did end up needing to lift the truck about 1” but I just put my floor jack under my drop hitch and one pump gave me just enough lift to fit the spring in.
Sumo spring website says you want 1/2”-1” gap between the sumo and the axle. I have what I guess to be a little less than 1/2”
Now, how did they help? I set my tongue weight to 800lb and I measured my truck and it squatted 1.25” without the sumo springs.
With the sumo springs, I had exactly .5” of squat. They’re squat busters for sure.
Disclaimer: This is just measuring the truck and then adding tongue weight. Trailer and truck did not move. static measurements. the springs may take a set.
I use this setup to measure tongue weight.
Sounds amazing, right?
Well, there are downsides. I drove off my curb to test hitting a bump and although it was much softer than hitting bump stops, it was much firmer than just spring would be. I think this extra load support will be great for towing but I think may be a trade off around town. I hope they take a little bit of a set maybe 1/4-1/2” after a bit of driving. If they do, I’ll have the clearance to be able to remove them without lifting the truck slightly. Then I can just spin them on when I’m towing.
I have had airbags before and these have some trade offs when compared to airbags. You’re trading adjustability for simplicity. Airbags tend to reduce down travel and up travel unless used with cradles. These have no effect on down travel but will decrease up travel.
Time will tell if the PROS outweigh the CONS.
I will be sure to report back and let you guys know if I love them or hate them and if I would do them again or if I would go with airbags.
Money was not a deciding factor but these ($289) do cost about half of the airlift 5000 ultimate plus if adding cradles. About $100-$150 less than the cheapest airlift kit and about half of a timber grove air bag kit
- easy to install.
- squat busters.
So what’s the deal?
2019 Ram 2500
Kit weight : 8 lb
Kit contents
Tools needed
7/32” Allen key
