Still lost on which aftermarket wheels will fit my truck
StrayCat
Sep 26, 2022
I have 18x8 +18 wheels on my 2022 and they fit great. They line up pretty well with the outside of the fender, maybe stick out 1/2" to 1" outside the fender. I will be purchasing a better looking tire with a more aggressive sidewall soon. And for what it is worth the website I ordered them from told me they wouldn't fit, but for the price I took a chance and they are perfect for what I wanted.
Super Helpful Thank You !!!
AH64ID
Moderator
Oct 5, 2021
What about a set of OEM takeoffs?
StrayCat
Sep 26, 2022
Yea, ive been keeping an eye out for those too. Unfortunately the ones I see so far , folks are asking huge $ still and have tires that I don't need. Ill still keep any eye out though, Kijiji is always changing
bigboost
Apr 9, 2024
go to tiresize.com and use their wheel offset calculator.....
Came here to say this.
You can look up the factory offset/backspacing of your stock wheels.
1010 Tires has an offset calculator, input your stock wheel width and offset, then plug in the specs of the aftermarket wheel you are looking at. It will tell you exactly how much it will move the wheel inward or outward.
No magic, pretty straight forward.
vdelgadillo1
May 16, 2024
Installed a
Fuel 20x9 with
35x12.5 Nitto Ridge Grapplers
Bolt pattern for Ram is 165.1 or called 6.5
Tires stick out about 1 inch
vdelgadillo1
May 16, 2024
Tires rubbed a little
Had to put a 2” leveling kit
I read “everywhere” and no one said it will rub. Had to spend the $600 extra for the leveling kit
AH64ID
Moderator
Oct 5, 2021
Where did you rub?
