Snow Chief 'after' the fact?
kingofbytes
Nov 30, 2020
Hi Experts!
I'm new to the group and I'm in the process of looking at a few used 2015-2017 2500 HD Rams. I plan on putting a plow on it. However, some of the trucks I'm looking at do not have the Snow Chief prep packages according to the sticker when I look up the VIN. (California/Arizona/Texas trucks seem to be missing this the most).
Has anybody worked through not having the Snow Chief prep package and adding something similar after the fact? Any methods or ways to do this?
Take Care>>>king
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
The Snow Plow Prep package consists of the 220 amp alternator and transfer case skid plate.
The Snow Chief Group consists of the 220 amp alternator, anti-spin rear diff, aux switches, clearance lamps and transfer case skid plate.
There should be no problem adding some or all of the components you feel you need/want for your setup.
kingofbytes
Nov 30, 2020
Thanks! Yea, the components seem simple enough - just wondering if there was a 'kit' or if someone had performed this and had lessons learned. I searched youtube for video's but couldn't find something relevant.
hawkuh60
Apr 21, 2021
Does anyone know if the snow chief package can be added to a power wagon or 1500 after the fact?
You dont need any of that to put a plow on, all the HD trucks come with the snow plow light wiring harness under the fuse box there is no issue installing a plow on trucks without the HD plow prep/ snow chief pkgs
You can't add the the AUX switch setup on a PW if that's part of what you're after. The swaybar disconnect and locker functions use up the wires in the bundle that would normally be used. It's still a significant retrofit to add even on a diesel HD that already has the AUX PDC. For switches, you're better off with an S-Pod or Trigger.
hawkuh60
Apr 21, 2021
True however I wasn't really looking to use a plow. I like/want the option and clean looking oem switches for other uses.
