Serious inverter power.......
oscar
Nov 18, 2021
Some of you may find this interesting....
Serious inverter power is an ongoing quest for many traveling away from home, be it RV'ing, overlanding or just hanging in the guvernment lands....... . I finally bit the bullet and am installing a system, but with a twist.....
Link is to my blog which is 100% non-commercial. The project is in progress, and updates are posted (almost) daily.
reese917
Apr 22, 2022
Very cool, I recently helped a friend with a similar set-up in his 5th wheel. I never thought about setting it up in the truck like that before.
oscar
Nov 18, 2021
That looks very nice. I am hours away from connecting it all.
Neat idea if you dont use the back seat, i am going with a solar setup when i buy a new trailer for now i have my generator remote on my bedside table so if the fridge beeps i just fire up the generator inverter without out getting out of bed :D
oscar
Nov 18, 2021
I thought about that, easy to do. Thing is, even producing only 750W/H, which is all I need without AC for a night, the thing burns 3/4GPH of gasoline on the fiver, and propane on the TC. The latter I have to schlepp bottles, the former I need to get into a gas station........ (I pump diesel at the truck pumps with a fleet discount, ask me about that....) Getting into gas stations can be "interesting" at 65 feet overall.
I actually changed my setup a while back instead of using the furnace on the trailer i have a 30,000btu open flame propane heater mounted on the wall. With it on low it heats the whole trailer i leave the vents open too and i get a long time on the 30 lbs tank (plumbed in to trailer gas line) no fans no issues i can go almost a week with no generator just the 2 batteries in the trailer its the perfect hunting solution for me
jsalbre
Oct 29, 2019
ID
Interesting set-up. Are you running the power from the truck to the trailer via DC or AC?
I've done a number of Victron installs, including the one in my current TT with a MultiPlus II 120x2, 800W of solar (room for 800 more) going into a Victron SmartSolar 150/85, 2 206Ah LiFePO4 SOK batteries, and a 60A Renogy DC-DC, all controlled by a CerboGX. Similar setup to what I ran in my AirStream back when I had it, but with more solar and the new 2 leg inverter. Between the solar and DCDC I run my AC full time when driving if it's above 75* and I can go about 8 hours like that. When I finally get back into the RAM I may add a second DCDC and then I could run the AC indefinitely as long as I'm driving.
Something to be aware of the, the MultiPlus isn't a 3000W inverter, it's 3000VA/2400W max.IMG_3860.jpegIMG_3847.jpeg
