Rpm @ 70mph
Tsscontractor1
Dec 2, 2022
Wanting to know the RPM @ 70 MPH for 2022 3500 SRW or DRW with high output and 3:73 rear axle running empty?
Thank you sir,
Kw
superjoe83
Jan 24, 2022
Thank you sir,
Kw
I dont have the exact rpm, but around 1700-1800, 22 drw, the srw trucks would have a slightly lower rpm since the tires have a larger diameter
tchur1
Jun 23, 2021
Srw and if I recall it’s about 1800. 3.73 rear end
Tsscontractor1
Dec 2, 2022
True- I wonder if anyone is running taller tires on the drw without it looking bad?
~1650-1700 on any SRW 3.73 truck. (~33" factory)
~1750 on Dooley. (~31" factory)
Need more details on tire size options.
35's+ on DRW will be detrimental to mileage and power (in 6th gear).
FWIW, my HO SRW with 285/65R20 runs right about 2K RPM @~85MPH (empty.)
John Jensen
Feb 11, 2020
My 2020 3500 HO Crew Cab, 4x4, 3.73, 275x70-18 tires (stock size) runs 1945-50 RPMs @ 80 MPH, and 15-16 MPG.
I lost my 70MPH data but recall it to be 1850-1860 RPMs
1705 for a SRW and 1779 for a DRW, using the OEM rev/mile specs. That’s empty or loaded in 6th gear. Empty vs loaded will not have an appreciable change in rev/mile if the tires are properly inflated. 5th gear obviously would increase the rpms to 2084/2175 respectively.
