Remote Start would not work at -9° F today with 1/2 tank of diesel
BighornHDRam
Dec 31, 2019
Today it was a brisk -9° F this morning, so I hit the remote start and nada. Tried it twice and it would not work, it worked yesterday at 16° F and I have 1/2 tank of diesel in the tank currently. Ended up having to go out and firing it up the old fashioned way, boy it was not happy. Turned over slowly and grumbled then fired up but after coming to life either the power steering pump or the CP4 pump was making some horrible noises that lasted for about 20 seconds. Tried getting a video but by the time I got my phone out the noise finally subsided.
What's the point of having a remote start if it get's to cold it will not function.
jkbrereton
Oct 18, 2019
Do you have a block heater? I can't imagine much of ANYTHING wants to work at -9F. I know I don't.
Sent from my Pixel 2 XL using Tapatalk
Epsilon Plus
Sep 11, 2020
All 4.5 Gen 6.7s have the heater installed, just not the cord (thanks, bean counters). You can order a cord from Geno's and install yourself to help the cold start.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
Did you try again when you were able to see the instrument cluster to see if there was a message displayed? When you hit remote start, did the parking lamps flash to show that the command was received? How long did you wait before you hit remote start the second time? If it was still in the middle of warming the grid heater the first time, then you actually cancelled the remote start process the second time you did it.
BighornHDRam
Dec 31, 2019
I've been using the remote start here in Wisconsin for the better part of 2 months here so I know how to use it. I hit the x2 like always, lights flashed and horn made noise and went to go get ready. Came back about 4 minutes later and truck is not running. Go open garage side door hit the x2 again and nothing happens, I then go unlock the truck push on the brake pedal and hit the start button and it grumbles to life but the cab heater did not heat up this time. After it starts I shut it off close the door and hit the remote start and then it finally decides to work after I go out in the -9° weather.
I have a block heater cord left over from my 2015 3500 but I don't want to install as I'm looking at going to a power wagon and being done with the cp4 time bomb after my 2 replacements.
