Regeneration Frequency Issue: MAF Poll
Please indicate which MAF your truck has and wether or not it has a Regeneration Frequency problem.
  • I have AARFN and a regeneration frequency issue.
    Votes: 15 46.9%
  • I have AARFN and NO regeneration frequency issue.
    Votes: 12 37.5%
  • I have ABMBV and a regeneration frequency issue.
    Votes: 3 9.4%
  • I have ABMBV and NO regeneration frequency issue.
    Votes: 2 6.3%
  • Total voters
    32
OLEJOE
Sep 24, 2021
N. Louisiana
Has anyone gotten the updated MAF yet and seen any positive results ? Just curious if this actually is the “Wonder Drug”.
DougB
Jun 5, 2020
Round Rock, TX
@scdo Had the new MAF installed by dealer but no improvement.
Seems we have at least 3 separate threads on this issue.
scdo
Apr 18, 2022
@scdo Had the new MAF installed by dealer but no improvement. Seems we have at least 3 separate threads on this issue.
Yep, it did not help at all.
DougB
Jun 5, 2020
Round Rock, TX
Did they do the MAF reset procedure @mbarber84 posted previously? If not, it may be going off the old lookup tables.
I am going to try to do that drive sequence today and see if it’ll reset even with the “bad” MAF. Hoping it will revert like it was new and take a while to learn the bad behavior.
scdo
Apr 18, 2022
You know, I’m not sure but STAR advised them the fix didn’t work. It couldn’t hurt for me to try that procedure myself.
Ostracize
Nov 29, 2020
Right behind you
.... Asking because I have the "tick" which is awaiting parts but also mine is regening about every ~350mi when it used to regen only at the 24hr mark... Honestly not sure what caused the change.. Like others I thought I caused it by not installing the correct filter but the correct one has been in for almost 10k now and no changing frequency.
Could my tick be contributing to the regens frequency?.... Unsure.
Edit: I have the German MAF in mine. It's never been replaced.
bobbo7915
Sep 29, 2022
no regen issues, every 24 hours except one time in 29,000 miles.
German sensor with an S&B intake and the oiled filter.
Ostracize
Nov 29, 2020
Right behind you
Cleaned my MAF(not dirty) and MAP (very dirty) and did the maf relearn drive cycles. The throttle response is noticeably better and fuel economy for a loop I'm quite familiar with is much better... Soo fingers crossed this might have a positive effect on the emissions/regen logic once it catches up to the changes.
ironmike
Nov 15, 2020
Bakersfield , CA
My MAP was just as bad and I cleaned & didn’t have a regen for 10 days , prior was every day !
Did you replace sensors with German or Chinese?
CaptainMike
Dec 9, 2022
The Great State of Jefferson
How did you clean them?
