My 6” fixed drop wont but my 8” adjustable sometimes will trigger it not all the timeInteresting discussion. I have a 4" drop hitch in my receiver and it does not trigger my backup alert??
The adjustment is for alert volume onlyI have a 8” drop hitch and it doesn’t trigger the back up alert either. I have my sensors set to the mid level.
I have the 8.4” Uconnect and in the settings icon you navigate to the setting for the parking sensors. I can adjust the front and rear sensors with 3 settings (low, medium and high sensitivity).There is no way to do that on my truck only the volume... does your have it?
I just went and looked and you are absolutely correct. It’s for volume. I read what I wanted it to be instead of what it really said.The adjustment is for alert volume only
You even tow bro?I don’t understand why people leave their hitch on for an occasional use. If you tow something every few days, fine, just turn off the rear park assist.
Same. First few weeks it didn’t care. Then one day it set it off and didn’t stop. Finally I just put it in the stowed position. Why it started after that amount of time is a worldly mystery.I have a 6" stow and go from B&W, the first 3 weeks it did not set it off. Yesterday it started setting it off, zero changes in configuration but its constant now. Very annoying. Why it just started is beyond me.
Its has been in the stowed position and in the 1st hole sitting pretty flush. Wonder if there was a software update? If its software driven, I dont think very highly of these engineers. Trucks normally alway have something on the hitch....Same. First few weeks it didn’t care. Then one day it set it off and didn’t stop. Finally I just put it in the stowed position. Why it started after that amount of time is a worldly mystery.
Yeah. That’s pretty wild if it’s been stowed and sitting in the first hole. It’s almost hard to see in the camera in that position… I don’t think there was a software update but I have no idea honestly. Mine just did it this past weekend so I’m not sure when yours started freaking out. I had to move it Saturday night.Its has been in the stowed position and in the 1st hole sitting pretty flush. Wonder if there was a software update? If its software driven, I dont think very highly of these engineers. Trucks normally alway have something on the hitch....
That is a serious hunk of IronI only tow a fifth wheel but wanted some protection from the careless drivers out there. It's a real solid chunk of iron and it doesn't interfere with the rear sensors. Gotta weigh 15 pounds. Can also use as a tow hook.
I'm curious. why do you ask the question, why don't you just try it out on your truck?If I turn off my rear parking sensors with the button will it stay off or turn back on next time I start the truck? Same question with turning it off in the menu. I don't care about the rears and rather keep my hitch in with sensors off.
Not at home where the truck is and impatient I guess.I'm curious. why do you ask the question, why don't you just try it out on your truck?
