Good evening all,
2020 POWER WAGON (LEVEL 2 KIT)
So I recently discovered that my door lock rod clip had broken at some point and I have only had the truck for roughly 9 month. Has anyone else had this issue with their RAMBOX rod clip failing? Not super worried about the issue as the part is only $2.50 to replace. I can still lock and unlock the box manually.
It is green in color and easy to spot with a flashlight if you wanna look for fun. Just open your RAMBOX and look into theopening near the latch mechinism. You will see a green clip that is attached to a rod on the center right or left depending on which side box you open.
I look forward to seeing ya'lls responses.
-Cheers
-Cheers
