Will_T
Ah. That makes more sense.It's a fleet truck. My friend has a construction company so they have more trucks.
What in the world were you doing that caused a hub bearing to fail on a full float axle to the point that it wrecked the spindle? Either serious abuse/neglect or it was put together wrong at some point. When properly installed and lubricated they rarely if ever go bad. Hub seals are another story
No not at all. How many miles on the truck?Nothing outside of ordinary driving. Pretty wild that a wet Timken style bearing spun, isn't it? It's definitely not something you see every day.
Ford and GM are the same i know of trucks from both companies that have been sitting over 5 months waiting for warranty partsThis seems to be the norm for Ram for some reason and not just with trucks like yours but all the Rams. I needed a new shock under warranty and even that was backordered. Crazy. I have a friend with a GMC and he has had a few warranty issues, including one complicated one with the DEF system. The local GMC dealer gets him in right away and always either has the parts in stock or can get them within the week. Of course, I don't really like his truck compared to my Ram so I just keep hoping that I don't have an issue that puts me in the "without a truck for months" club.
I do have the two open recalls on mine, the transmission dipstick and vent, and the grid heater relay. I have called many times to see about getting it done and they always say no parts available for me. I am sure they have fixed truck on their lot so they can sell them. But for a customer with a 2021 that I did not buy from them, they will not do the recalls. This may be a problem just with my big chain dealer as others in different locations and with different dealers have had the recalls done, but who knows. I am hoping that by next March 2024 when I need fuel filters and an oil change, maybe they will be able to do the recalls at the same time. Until then, I just give up trying to get them done. Disconnected the heater relay and have not had an issue with the transmission blowing fluid out the tube so maybe I'll be fine for the long term.
The bearing was not set right then it likely was to tight….Nothing outside of ordinary driving. Pretty wild that a wet Timken style bearing spun, isn't it? It's definitely not something you see every day.
Not trying to be an a$s but it sounds like you don't even need an HD truck then. I don't understand all the HD on the road that the owners don't have a use for an HD. I see them all the time, no hitch or have a cap/topper and the receiver hitch is like brand new. I just am curious why anyone would pay for something they don't need.52K, so it still under the powertrain warranty.
It;s never towed and never had much weight in the bed. The only reason it even has a ball mounted is to move my log splitter around. I use it to get in and out of a remote mountain property I own that's about 6 hrs away.
The question is kind of off topic, and I need my truck... But I own lots of stuff I don't need but have just because I want.I don't understand all the HD on the road that the owners don't have a use for an HD. I just am curious why anyone would pay for something they don't need.
L commentNot trying to be an a$s but it sounds like you don't even need an HD truck then.
Sent from my Pixel 6a using Tapatalk
Slightly too tight will do just that on oiled bath bearings they spin just enough to last a long time i have seen it on trailer spindles and ff axles a few times over the years its usually just enough spinning to score the spindle but not overheat and ruin the bearingBearings that were put together wrong usually don’t last 52k. Super weird
I’ve just always found it hard to achieve slightly too tight. Whenever I install taper bearings that next notch in the castle adjusting nut is always way too tight so it gets backed off.Slightly too tight will do just that on oiled bath bearings they spin just enough to last a long time i have seen it on trailer spindles and ff axles a few times over the years its usually just enough spinning to score the spindle but not overheat and ruin the bearing
Dealer told me today that a rear axle bearing went in the PW and it scored up the spindle tube. The whole rear end needs replaced. Under warranty, so no problem, right?
The big deal?
There are ZERO available in the whole country.
Here's a parts nightmare story.
Jan 4th while at Mayo Clinic in Rochester Minnesota truck was hit in parking lot. Driverside rear cab corner and dually fender needs replaced. Body shops can't get the parts for a brand new 3500 dually. It's been 6 months!
At this point I'm considering finding a chop shop to get me the body panels. I'm mostly kidding........mostly. I've had the insurance payout just sitting in the bank. Truck is brand new 2022 3500 DRW limited.
I sadly have to admit I'm embarrassed to even drive it. Not sure what I can even do at this point.
What rights do you have if you can’t get the parts for your vehicle repair?
Lemon laws may protect you if your car repair is delayed due to a lack of replacement parts. Lemon laws are different in each state, however, they typically require a dealer/manufacturer to repair a defective or “lemon” vehicle within a certain time period or mileage limit, and allow the dealer/manufacturer a reasonable number of attempts to do so. Most lemon laws define what is reasonable by limiting the number of repair attempts and the length of time that the vehicle is out of use or in the service shop. In Pennsylvania, for example, if a new car is in the repair shop for more than 3 repair attempts or 30 cumulative days for a problem found within the first year or 12,000 miles, the law presumes that the dealer/manufacturer has failed to repair it within in a reasonable time.
