TNmountainman
- Joined
- Sep 29, 2023
yes. yes I do. I have one that weighs 7000lbs and probably has about 8000 in logs sitting on it right now. I can also easily put my 13,000lb skid steer on my equipment trailer and haul that.Without a load 75 mph may not be enough heat for a good passive regen if the filter is full. I often see passive regen at 75, but also often don’t see much if it’s slightly downhill or with a tailwind. 18-20 mpg won’t do much for passive regen, but also doesn’t fill the filter.
You’ll want to get your average mpg down below 15 for an hour or two to get a really good passive regen, below 12 would be better.
Got a trailer you can tow?
The problem is, that won’t clear the code. From what i have been reading (and learning), the P242F code means the ECM thinks the DPF is full of ash. Which based on another users speculation, is really soot that has accumulated from 2 straight months of one mile trips to a jobsite I have been making 3 times a day without ever having a chance to burn off.
Once the P242F code is active, it literally cannot be turned off without computer reset of different things like the DPF timer data, and such.
So that’s my next plan of attack, to try and go in with AlphaOBD and a security bypass gateway and reset everything and then perform an active regen and see what happens.
