Possible problem after clock spring replacement.
Gray8188
Oct 18, 2021
When I was putting a leather steering wheel with audio controls on my 21 2500 tradesman I broke the clock spring removing it. So I bought a new one and replaced it. Everything went smooth and works as it should. But now when I press the push to start button there is a couple of click noises behind the dash right around the start button as it’s starting. Not like a struggling to start battery click. And it does it when I turn it off aswell. Any idea what it could be? Do I have to get the clock spring calibrated or something?
Aug 12, 2022
When you push to start, the steering wheel is automatically unlocking. (This is the lock that prevents you from spinning the wheel when the truck is off.)
Gray8188
Oct 18, 2021
Just went out to test it out. Feels like the click is in the gear shifter. I’m wondering if it’s the shift lock. Can replicate the noise by pressing the brake pedal when it’s running in park.
Gray8188
Oct 18, 2021
Just don’t know why it’s doing it when I start the truck and when I turn it off. And it’d it’s something to be concerned about.
Aug 12, 2022
Noise is happening when It disengages and engages… Most likely It’s an alignment/fitment issue.
Aug 12, 2022
The part I circled is the manual overide to shift the truck into neutral. Is the noise there?
Gray8188
Oct 18, 2021
Almost thinking when we pulled the plastics off I hit it and knocked it out of place or something.
Gray8188
Oct 18, 2021
Or the shifter isn’t in park all the way.
Was thinking that but it seems to be. The shifter has always been a little on the loose side with this truck so idk if maybe that’s causing it. I’m taking it on for a few warranty issues soon I’ll have to add this to the list
