Picture Request From Someone With A 6.4
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
I’m looking for someone with a 6.4 to get a few pictures for me. Pictured below is the brake booster with the vacuum line highlighted purple, and the vacuum pump with it’s vac line highlighted purple. This is the same vacuum line assembly, and it tee’s off and goes to the engine (I’m assuming intake manifold). I need some pics of exactly where it’s plugged in at the engine, so I can see if I can retrofit the same vac port provision on my 2017 6.4 that has hydro boost.
Bugdude
Jan 23, 2021
Not sure if this will help. Not real easy to get a picture where it is attached.
This is from the side by the vacuum booster, it goes in under the intake.
Bugdude
Jan 23, 2021
This is looking from the top of the intake down. You can see the line on the top left going under the intake.
Bugdude
Jan 23, 2021
This is another one from the vacuum booster side showing it going under the intake.
jadmt
Aug 29, 2020
Age
65
Missoula
i think it does but I do not have the dexterity or nimbleness to look behind the engine. hope this photo helps a little.
Bugdude
Jan 23, 2021
It's hooked up basically where the "foil" is in this picture
Bugdude
Jan 23, 2021
You can see in this picture where is attached
