PCM Recall Z87 - Engine Serial Number Location
SeaBee-1
May 14, 2022
I have a 2022 Ram 3500 S.O. Cummins. It only has 1,400 mi on it. I’ve had no issues with it so far. But I received a letter that it is part of a PCM recall. The dealer needs the engine serial number to order the part. It’s somewhere on the top of the engine? So they want me to bring in to find it, then bring it back again once the part is received.
Does anyone know where this is at and if it is easily accessible? It would save an 80mi round trip twice! Thank you!
ESN is on a sticker on the side of ECM
I just stuck my phone down below the intake and took a couple pics till i got a clear picture, that is easy or go from underneath
Here is a picture of mine for reference on what to look for
SeaBee-1
May 14, 2022
Thank you both very much! I found it in both of those spots! You think the dealers would know this and save customers the hassle!?
You can also cross reference the ESN from a VIN on the Cummins QuickServe site.
Wholeo
May 12, 2022
Been over 5 weeks since my local dealer said they were going to order new ECM as part of the recall, they have my trucks VIN in the system since I bought it there. Called today for a update and was told that their order got kicked back because they need to have the actual serial number off the engine. No issues with the truck, but their customer service has a lot to be desired because I should of been informed about this several weeks ago. After going thru this thread I know where to find the number I need and phone it in. Thanks!
superjoe83
Jan 24, 2022
The easiest place to find it is on top of the valve cover in the rear, behind the crankcase filter, it will be a white sticker
