Nexen Tires (factory installed)
DepotsNutz
Apr 2, 2021
It could also be load related. Have you gone on a CAT scale while fully loaded?
The tires are rated for:
3085 single
2835 in a dual
Front tires - 6170
Rear dual tire - 11340
If you are exceeding 6170 on that front axle you might get some odd wear patterns.
Yes, not even close to the load limits.
Larbohn
Sep 25, 2022
Has anyone ever seen anything like this? At first I thought "curb rash" but at least 3 of may 6 tires (2022 F350 Ram Laramie DRW are doing this and the others are starting. Zoom in and you'll see the rubber itself came off and I'm looking at white bands underneath.
BAT3500
Nov 29, 2020
My nexen's have done the same thing. Have about 26k on them.
jsalbre
Oct 29, 2019
ID
Looks like marks from rear dually tires rubbing on each other as they flex.
Larbohn
Sep 25, 2022
Has anyone had any luck getting Nexen (or RAM) stand behind them. 20X miles (started around 15-16. Truck bought new last December
  • Haha
Reactions: CFE
Larbohn
Sep 25, 2022
Yes, the rubber has peeled off. I don't know if the white showing is a belt or another layer of rubber
PRS
Feb 23, 2019
Arvada, Co.
It's the same layer of rubber that makes up the raised white lettering. Mine did it too. Got rid of them for some Michelins.
Blythkd1
Feb 8, 2022
Good luck getting someone to stand behind them. It's near impossible to get either mfr to stand behind OEM tires when they fail, let alone just look bad.
