New Noise coming from dead stop
UNifc6pF
May 28, 2021
I'm going to take it in, just curious if anyone else has heard this before. It goes away after taking off as seen in the video. It seems if I try to take off as slow as possible , it might not do it, but under any type of acceleration I could reproduce it today.
UNifc6pF
May 28, 2021
Found the Source
(this has audio; it's loud)
Ran it to dealership, they said it's basically just a dust cap to protect the pinion bearing. They got a new on order and new bearing .. not sure if full kit or just the seal to be honest.
I was able to use a couple flat heads and push it up on the drive shaft a couple mm and it had enough friction to hold it there and stopped the immediate rubbing on the housing. /shrug
Its not to protect the pinion bearing its to protect the pinion seal. If its not leaking oil the pinion bearing is fine. I would much rather them change/remove the dust shield than have them pull a perfectly fine diff apart to change a bearing that does not need to be changed…
jetrinka
Jun 11, 2021
They’ll have to pull the pinion flange to even access and change the dust shield. Not sure Id want some green dealer tech messing with that pinion nut and reinstalling it “incorrectly”
If my memory serves me right its a shimmed pinion so pretty hard to screw up, if it was a crush sleeve i would be just cutting the dust cover off and not letting the dealer change it lol
jetrinka
Jun 11, 2021
Gotcha. Wasn’t aware of that.
Am I the only one here that fears dealer “techs”?
jsalbre
Oct 29, 2019
ID
Don’t worry, I’m sure they’ll just wail on it with a hammer until it says in place. Either that or cover it in hot glue.
UNifc6pF
May 28, 2021
Thanks, it's indeed the pinion seal. This is definitely pushing the my pool of knowledge, especially when trying to speak intelligently.
IIRC, he said it's just the seal he'll replace while he's "down there". This was coming from their senior tech not a green tech. But I do agree. I try to avoid replacing things that aren't broken.
Re: the cap spinning, prying it up against the drive shaft held up camping over the weekend. I'm going to talk to them more as I still can't find that part by itself so I'm curious what's going to be replaced and how it will keep from falling down again.
