OneBadBernie
- Joined
- Feb 24, 2021
Well, I have not had a great run with this new truck since I got the thing. I have 1850kms on it not a whole lot. Here's my problems, I will be calling fiat Canada and the Ombudsman tomorrow.
So to start off with the issue I'm going to Ombudsman over.... I woke up in the morning and went to timmies for coffee on reversing out of my driveway I get an error tells me to wipe the sensors. That makes sense we are in the middle of a freeze thaw cycle and my truck is filthy. So I go get coffee and wipe the sensors....the issue is still their tells me to while the sensors....okay well it's 2 degrees Celsius at the moment and it's gonna get warmer in the afternoon so I zip on over to the wash. Well backing out of the wash bay the same thing happens...wipe sensors.....then I go out and look and would you know it, across the top of the sensor on the driver's side rear bumper is a crack across the top of it, no impact dmg in the plastic around the sensor and a small chip in the top corner. What I assume is dmg from freeze thaw...must have been a **** sensor and water got in their, no big deal call the dealer explain what I found...no problem bring it in....the next thing I know they are telling me a rock broke physics and some how struck the rear end of my vehicle with enough force to break the sensor and that little chip they use as their evidence... despite admitting that water could do that and their was not dmg right beside the chip to anything else... Claimed that if he warrantied it he would have to send it back to Fiat and they would see the dmg and charge him for the part...I'll attach an image of the broken sensor, my opinion is that it isn't rock dmg and is likely from water and freezing temperatures. That's issue 1(the idea he would send broken parts back to Fiat to be investigated is laughable to)
Issue 2, my dpf display on the truck screen doesn't do anything, the truck has gone into Regen 3 times and told me such but that meter hasn't moved at all. They say it's working....I agree that the truck itself is functioning and that Regen is occurring. However the DPF isn't sending its diagnostics to the HUD
Issue number 3/4 my Sirius satellite radio is terrible. Has terrible signal strength basically gets blocked by slightly tall trees and double wide trailers... overhead powerlines ect....said they did an 12 km test ride and it was fine...ya it would be on a wide open prairie highway drive through town is another matter, my 2019 1500 only cut out in 1 spot of my commute this thing cuts out all the time....they say it's fine...... And issue 4, massive lag from the blue tooth connection makes it useless, it lags a good 2 seconds so using it to answer phone calls doesn't work as it's like talking to someone who is on the moon with the delay. The same goes for music tell it to play or stop and the command takes two whole seconds, try to watch a video and the fact it's out of sync is massively apparent. They tell me it's fine that's how blue tooth works and that my unit is up to date...my response was really no blue tooth unit of any sort has done that to me since it started being an option for PC components and headphones, and that I had the 12 inch Uconnect display in my 2019 and it didn't behave like that. I'm really at my wits end here and am almost ready to go trade this thing in for a ford so I don't have to deal with a Chrysler/dodge/ram dealer ever again, I like the truck but my experience has been garbage when it comes to service...my 2019 was one of the worst fit and finished vehicles I'd ever owned and they couldn't even fix the trim properly it kept popping off and you could see that they didn't put any effort into doing things right, they scratched.my rim...rather gauged and took out a tire and tried to blame me on my 2019...they then scratched my new rim again putting on tires just a few weeks later. This whole experience has been hell, I shouldn't have to fight and escalate every damn little thing to have it fixed. I don't care if thing break just support your damn products
