Mismatched spare tire?
Skid51
Oct 17, 2023
Anyone with 37’s have experience running a 35“ spare? I imagine you’d be ok from a handling and safety perspective to use one to drive, temporarily and conservatively, to a tire shop but is there risk of grinding the rear LSD on dry pavement if rear tires are mismatched in size?
Enve46
Jul 20, 2021
I would not run mismatched in the rear. Front temporarily will hurt far less
Nothotdog
May 15, 2023
Massachusetts
I'm not quite at the point where I will get new tires, but I've been going back and forth between 35 and 37. Would you think there is a chance that a 37" spare would fit under the bed if it was deflated quite a bit (with the assumption that I have a solid compressor to air it up if/when needed)?
Enve46
Jul 20, 2021
I do not know to be honest. My spare sits in the garage. I think some have gotten it to fit by removing the heat shield but if I remember correctly it’s the hitch you hit with a 35+
Nothotdog
May 15, 2023
Massachusetts
Thanks! I'm thinking the play may be like you suggest, where if a rear tire fails, swap out a front tire and put the spare on the front.
Soapy
Jul 9, 2022
It was all we could do to get a 35 inch spare under the bed. 37s no way. If you go 37s get a 35 inch spare. You have a 50/50 shot that the front tire would go flat. Whichever tire goes flat run the off size on the front and don't run in 4x4 until you get it fixed.
el_barto
May 25, 2020
On road, actually greater odds of a rear flat. Front tire rolls over sharp object that is laying flat and kicks it up, rear tire rolls over it as it’s bouncing and gets punctured
Offroad, I think higher odds of rear flat as well, since you pivot around rear tires it might be more likely to catch a sharp rock in the sidewall
More weight on the front helps the front get the puncture. I have yet to puncture a rear tire its always the front
el_barto
May 25, 2020
Please give us the exact percentage on rear vs. front flats.
X %F : 100-X %R
I honestly don’t know, it’s just what I’ve read and it makes sense. And On my bike I know I get WAY more rear flats than front flats.
