Lower Front Bumper Protection Plate
mikenacarato
Jun 26, 2020
TN
For those looking to ditch the front lower spoiler on the 19-20 power wagons, the CJC intercooler guard will fit and add a small level of protection to the truck. After installing it, I would definitely not put it in the skid plate category as it does have a lot of flex but it does look good, and it would shield from some debris to a certain extent.
jadmt
Aug 29, 2020
Age
65
Missoula
good deal. is it a straight bolt on? hopefully it will keep some of the winter road slush from the synthetic line.
unxpctd
Jul 28, 2020
Looks great! Hopefully it doesn't get in the way of the front license plate mount (for those of us that require it).
jadmt
Aug 29, 2020
Age
65
Missoula
I went to CJC's site and looked at the install instructions and it tells you how to mount your plate. the factory plate mount on the PW or at least on mine is kind of a poor design for a vehicle designed to go off road.
mikenacarato
Jun 26, 2020
TN
You do have to remove the front plate holder but i suppose you could mount it how i did my front lights. see pic above
mikenacarato
Jun 26, 2020
TN
Any idea if this will fit a non-PW model?
Yes this was designed for the diesel but after reading the install instructions before I ordered it, I saw my truck had the plow brackets they referred too. It goes on exactly like the install instructions say even though they do not list the power wagon as a truck it will fit.
unxpctd
Jul 28, 2020
I read the install instructions after making my post about the license plate bracket. Then I saw you mounted your lights on the same holes. Looks great!
This will definitely be on my list of mods in the future after I order my PW in a few months.
jadmt
Aug 29, 2020
Age
65
Missoula
that is what the cjc instructions tell you to do. just mount plate directly to the bumper using the old holes.
DMC1
Aug 1, 2020
Southeast
it is designed for the intercooler on diesels so............
I went to the CJC site and it does not say that it will not fit. I believed based on what I saw it will fit.
jadmt
Aug 29, 2020
Age
65
Missoula
it is not made for a power wagon it is made for a diesel as power wagons do not have inter coolers. it is made for hd diesels but just so happens will work on a PW.
RndmGlitch
Nov 14, 2020
This is all good info. I just wish they would not refer to those brackets as "snow plow" brackets though - because they are not. They are "Secondary Energy Absorbing Structures" or as RAM called them, Compatibility Brackets. They make trucks that have a higher stance "compatible" with smaller vehicles in a crash. NHTSA required.
Anyway, that is another story...
RndmGlitch
Nov 14, 2020
That being said - I really do like the looks of this. I have been working out in my head some type of splash guard or skid plate to protect the wench and cable for when I remove my front valance. This gives me even more ideas!
jadmt
Aug 29, 2020
Age
65
Missoula
been doing the same. I can't believe they do not have at least a splash guard to keep the crud off the winch line.
stickshifter
Dec 1, 2020
Since this was made for the diesel, maybe those holes are necessary to provide air flow to the intercooler (to help with cooling). ?
I'm guessing that on a gas truck you could cover those holes if you are worried about crud getting through and building up on the winch line. Emphasis on "guessing" :)
AnthonyD1978
Jul 23, 2020
Arizona Mountains
Should be no problem covering those holes on a gas truck. That's where the factory air dam goes anyway that the OP removed and that air dam has no holes. I removed mine as well the day I got my truck.
desert_wagon
Dec 8, 2020
so chopping em off wont hurt anything, they hang kinda low.... (edit: it looks like they are held up with 2 bolts.....oooo thats a win-win)
as for the intercooler guard.....$299 is a bit steep. Could have a local machine shop make one in 0.250" and powdercoat for less....just syin'
