Loss of Power
FishermanJer
Jan 20, 2022
I didn't replace air filter yet. it didn't need it. I replaced the Fuel Filters and oil change.
FishermanJer
Jan 20, 2022
Reminds me of my 47RE days when the governor pressure solenoid would go out. It wouldn’t kick down to a lower gear like it should when you get hard into the accelerator pedal.
How did you fix that?
flan
Aug 16, 2019
So the fix was a replacement solenoid kit. Dnj components made a upgrade kit with a more reliable solenoid. I’m not sure this is your problem as these transmissions are decades apart.
Just reminds me of the good ol days. Maybe someone more wiser can chime in if these parts are still in use today.
diesel_driver_3500
Apr 3, 2021
I believe that the fix is the Banks Pedal Monster.
My truck does not suffer from this very often, and now that I am aware of the issue, I try to drive accordingly. If it starts to happen more often, then i will install the Pedal Monster.
If the fuel filters are good, and properly installed, then the fix is a trip to the dealer. It's a new truck, and shouldn't be slowing to 30 with full throttle.
CdnHO
Nov 17, 2020
Ontario
Which mopar engine air filter did you install:
68517554AA
Or
53034051AB
Or
Aftermarket
AA bought them way before this became an issue. Installed it a few weeks ago. No issues so far but did keep the original just in case.
baker01
Nov 16, 2021
The Pedal Monster will not fix this issue, this is more than pedal lag. If it does it again prior to getting it to the dealer, you can try forcing a downshift with the "Electronic Range Select (ERS) Operation". See your owners manual for detailes. It won't fix the issue but could give you a better idea of where the issue is.
Aketay
Apr 5, 2020
Lost power this week, I can make 6psi boost in any gear with the pedal to the mat. It actually runs pretty good when your turbo is toast. New turbo next Tuesday.
mbarber84
Sep 10, 2021
Washington County, PA
That is the incorrect filter for a 2019+ Cummins truck. And they have shown multiple times to chase a lack of power or throttle response, as well as P0299 turbocharger underboost codes, and even more frequent regeneration cycles.
The air filter is the first thing to rectify moving forward. I would highly recommend changing it to a mopar 53034051AB or a Fleetguard AF27684
Then see if that helps the issue you’re experiencing.IMG_3421.jpegIMG_3422.jpeg
Then see if that helps the issue you’re experiencing.View attachment 62732View attachment 62733
Which air filter brand / number was installed when you had the issue?
We got off on a tangent somewhere with @CdnHO . The OP says he hasn’t replaced the air filter yet, I take that as the OE one is still installed.
The OP doesn’t appear to be having an air filter issue. The truck will tell you when the air filter is restricted, long before it limits speed to 30 mph uphill.
It’s acting more like a fuel delivery issue, but could be programming/computer, transmission, turbo related… or something else.
The lack of a downshift and lack of a CEL makes me think it’s a computer issue.
mbarber84
Sep 10, 2021
That might have been my fault. I saw the AA filter reference and got lost. Either way that’s a known filter for underboost codes / slow throttle response. I lived it. My 2022 Ho was gutless off the line with that filter installed.
The OP’s truck is a 2021, you’d think it would have at least one filter change on it by now, unless the truck sits a lot.
Yeah it’s easy to do with all the air filter issues.
I would have also thought the OP would have changed the air filter by now, if not by miles at least by months.. maybe it was a late 21 purchase.
mbarber84
Sep 10, 2021
Agreed. And from the description it sounds like turbo lag / underboost….
CdnHO
Nov 17, 2020
Ontario
My bad. :eek:;)
