Loose 7 pin trailer connection
RV_Goose
Aug 14, 2020
I guess I need to make time to go to the dealer. The in bed 7 pin trailer connection is loose fitting. The 5th wheel connector was nice and tight on my 2013 RAM 2500. But it was aftermarket, not a stock RAM one.
Are all RAM in bed trailer connections loose fitting?
farmallboy
Stump Killer
May 23, 2020
My 2019 is still tight after about 15 plug unplug cycles.
How loose is loose to you mine has some wiggle but no loose connections
RV_Goose
Aug 14, 2020
I have to plug and unplug trailer a couple of times to get a complete connection. Once connected it stays until unplugged.
On the trailer end take a small flat screwdriver and open the tabs back out so they make a better connection the male end usually needs this every couple of years i find
RV_Goose
Aug 14, 2020
Well...the trailer plug has the female end. But I can do that on the truck side.
Firebird
Sep 24, 2020
Mine is not terribly tight either. Kept getting constant warnings about being disconnected. It never came out, because the tab on the cover locks the plug in place. Dielectric grease did eliminate the warnings on my dash
Frank
Sep 29, 2020
Missouri
The female contacts should retain the male contacts with x lbs of force via spring action. Dielectric grease is bridging the gap and masking the problem. I would test how it retains on the bumper plug and make sure the blades on the truck side aren't compressed.
Where my arrow is on the pic of the male plug you push the tabs more towards the center slightly so it has the force needed for a good safe connection
RV_Goose
Aug 14, 2020
Trailer plug is the male end the terminals are female
LOL. Guess it's confused. Yes, overall the trailer plug is female because it 'inserts' into the bedside socket. But, inside the bedside socket are the metal blades that insert into the 'female' trailer plug.
It is still considered male if you walk in to any part store and ask for a male 7 pin you will get the trailer end
Frank
Sep 29, 2020
Missouri
Male and female are the contacts. Plug and receptacle are the housing/insulator. You can mix and match. And if you want to get real technical, these are hemaphroditic because of the 7th position.
Straight from the self proclaimed trailer specialists at e trailer
