Looks like a new recall incoming for the HO engine - MOD EDIT: NOT confirmed for HO - this is Chassis Cab SO trucks recall W57
Hawk375
Jan 14, 2020
"Chrysler (FCA US LLC) is recalling certain 2019-2020 Ram 3500, 4500 and 5500 cab chassis built with a Cummins 6.7L High Output engine. Inadequate warmup protection can cause a lack of oil film on the engine connecting rod bearings while the engine is reaching operating temperature. This can result in engine damage and connecting rod failure, which could potentially puncture the engine block."
https://www.nhtsa.gov/recalls?nhtsaId=20V511
[mod:] The recall is for Cab & Chassis trucks only which are not HO. FCA must have gotten a typo or something wrong. Thread title also updated. Sorry @Hawk375 but the thread title is causing a bit of a trainwreck and multiple threads started on this W57 recall issue.
D
Deleted member 80
Guest
Reading the attached documents, this is for C&C trucks, not pickups, and not HO. The C&C Cummins tune is different than pickups.
Rich
Banned Member
Feb 3, 2020
My 20 drw hohd aisin doesn't have any recalls or campaigns
NordicNevs
Aug 29, 2019
Interesting
19 DDSRT
19 Ram 3500 Laramie Megacab HO (patriot bus)
I'm trying to wrap my head around how Cummins can control oil flow to the the lower connection rod bearings via the ECM?
"Warmup protection" = (more) reduced power modes when cold.
If you look closer, at the correct recall documents for W57, it's clear this is for DD and DP trucks, (DD) 3500 Cab and Chassis and (DP) 4500/5500 Cab and Chassis trucks.
FCA US LLC Recall Part Numbers
W57 Cummins 6.7L High Output Engine Calibration
08/28/2020
New Safety Recall Advanced Communication – W57
September 2020
Dealer Service Instructions for:
Safety Recall W57 / NHTSA 20V-511
Powertrain Control Module Software
NHTS
Subject: Inadequate Warmup Protection
Speedracer93CobraR
Apr 24, 2020
Just called and got the 5500 scheduled. Thanks for the update because I have not received a mailer and this truck is about to get busy traveling several states in our region. We are under 10,000 miles so hopefully nothing is hurt yet.
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
3500 chassis cabs, yes. believe there are a few typos on the notice.
2Many12Valves
Sep 10, 2020
I was assuming the HO engine in the 3500 pickup truck would be the same as a chassis cab?
Speedracer93CobraR
Apr 24, 2020
I couldn't get the HO in the 5500 chassis cab. If I am correct and thats the 1,000 ft./lbs. torque.
