4. Feature execution - There are a few features on this truck that are nice features, but poorly executed. The first is the Auto High Beams. Whoever wrote the user story (defined how it should work) for this feature must not drive at night. If you enable this feature in settings then you MUST keep your turn signal/high beam stalk pushed forward for auto high beams to work. However, when you use the turn signal to indicate a turn or lane change, it's very easy to pull the stalk back accidentally then your high beams turn off, and you won't notice it until the next time you're driving at night and realize your high beams aren't coming on. Also, there is no way to override the truck's decision about whether the brights should be on. To manually override and turn the brights on, you have to go into settings, navigate the menu, find the right setting, turn it off, then you can push the stalk forward and get them on, this isn't going to happen while your driving. Why does this matter? It matters since the truck's light sensors seem to be oversensitive to reflections from street signs and keep turning the brights off. There's also no hysteresis built in so the brights will go on and off often on certain stretches of road. The F150 did this right. Just turn the setting on and the brights come on and off as the truck determines, but if you push the stalk forward, you can override the truck and force the high beams to stay on. Another poorly design feature is the gauge/center stack backlight control. The dial isn't fully linear meaning you can't just rotate from dim to max brightness as you would expect. If you rotate it to the highest brightness, without clicking it into "max brightness", there is a big step in brightness between those two settings. Why does this matter? Well if you're driving in very overcast days or at twilight, and the truck turns its headlights on, the gauges will dim to the point they're very difficult to see. The only way to fix this is rotate the dial to the max position which it clicks into. The gauges are now readable but as soon as it gets fully dark, they're WAY too bright in the cab and are distracting. Another feature is how you select channels on the sound system. In GM's, you can set your favorites from any receiver (satellite, FM, or AM). Your favorites then present all these to you and you can select from what you like without needing to switch receiver modes. The system does that for you. On the RAM's 12" system, if you want to switch between an FM station and a Satellite channel (which I do often), you have to switch screens to the source screen, then select the mode you want, then switch back to the main screen to see your favorites, then select your favorite from that list, all while you're driving - not going to happen. Yes, there's a button on the back of the steering wheel, but you have to rotate through all the sources to get to the one you want. GM did this right.
I list these as examples of where Dodge had good ideas, but really don't spend time undertanding their cutomers like Ford and GM seem to have done. I could go on, but the point is made.
Ok, I'd like to hear other's thoughts about their experience with their new Ram 2500.
