So I recently picked up my new 2022 Laramie, I like everything so far except the bed rails are sun faded from sitting in a Mexican parking lot for 6 months, and the fact there are no amber parking lights. Much smarter folks from here did show me that’s exactly how it’s supposed to be. The old marker/ signal lens is strictly for turn signal only on models with led lights ( my 2022 Tradesman with incandescent lights has amber front marker lights.) I know the led that wraps around the headlight is as designed but I want to activate the amber parking lights. When removed the light plug has an ground and 2 conductor areas When I supply 12v to each of the contact areas with a ground the bulb lights up in bright ( signal) and the other filament ( park) lights up. The bulb has both filaments like the old 1157 bulbs. Looking into the headlight bucket you can see 3 points of contact for the bulb to operate in both parking and signal capacity . On the headlight connector there is a missing wire could this be the wire for parking lamps in trucks with incandescent lights? When I turn on my light switch to parking lamps I have the amber side light on the headlight housing and the white LED surround and my cab lights illuminate, but there’s no amber showing front facing. What I’m looking to do is activate the amber bulb in the turn signal housing so when the lights are on I’ll have amber in the front. All input greatly appreciated.
