Just about finished with the 23 3500 build
jimblack
Dec 9, 2023
Just bought a new 23 3500. Wasn't really shopping but found a deal for over 16K off of MSRP and it was exactly what I would have ordered so I picked it up. It's identical to my 15, 3500 and I had it set up just like wanted it.
So here is what I have done:
All Carli Suspension. 3.25" coils, King 2.5, Sway bar, Track bar, Radius arms, Add a pack, Long bags, steering stabilizer hi & low.
S&B 52 gallon tank and Cold Air intake.
Rigid flush mount back up lights.
Baja designs 20" light bar.
AirLift onboard compressor EZ7400
OEM Bed lights
Recon White Cab lights
Toyo MT 38x13.5x18
Method 701 HD 18x9
AMP research EXTREME steps
Still to add:
Bushwacker flares
PPF wrap in Matte
Tint
Gained right at 6" on front and rear over stock.
Been a fun build. Sad to see my 15, 3500 go, but thats what it takes i guess.
Jqueen
Jul 22, 2022
Mine is on that track as well. Most of what you have done is complete. Good ideas for my future add one.
Sweet ride
Bluedevilman
May 28, 2021
Magnificent sir. If only I had money and time. Lmao. Really looks spectacular.
Sent from my SM-S908U using Tapatalk
tchur1
Jun 23, 2021
Looks great! Would love to hear your initial impressions ride quality over stock. I know its hard to quantify but my wife hates how my truck rides today so trying to see if the investment it worth it.
jimblack
Dec 9, 2023
The stock ride on 1 tons are awful. Like riding a horse. Even with all the new suspension, you are still driving a 1 ton. It's all in what you expect i guess. I've been driving a 1 ton for 10 years and just expect it to ride rough. They only ride good when loaded with a couple thousand pounds. However, with all that said, the aftermarket suspension gives it the best ride you can possibly get. Carli/Thuren and Kings are superior products over stock by a long shot.
Lower tire pressure and weight in the bed is about the best advice I can give if looking for a better ride.
Jan 17, 2024
East Coast, USA
Wow that truck is perfect. Seriously. Bravo
Review on the S&B CAI please? I’m thinking of doing it, just don’t want any negatives like CEL or warranty problems. Hoping for more turbo sound and some slight increase in throttle response and mpg. Thanks.
jimblack
Dec 9, 2023
Thank you.
I ran a AFE on my 2015 Cummins. It was LOUD. However, I have not removed the side cover nor the top cover on the S&B. I will most likely start with the side cover then the top cover if not loud enough. As far as Throttle response, its hard to tell because it was put on a nearly new truck. No codes. Shouldn't ever be a warranty issue, but that is relative.
Scooter29
Mar 20, 2021
OEM Bed lights
Toyo MT 38x13.5x18
Method 701 HD 18x9
Still to add:
Bushwacker flares
PPF wrap in Matte
Tint
Do you have the 1” block also with your add a pack? I also have the add a pack but didn’t use the block and interested in the long travel bags. Just not sure if I’ll have enough room with only the 1” lift the add a pack gave.
jimblack
Dec 9, 2023
Yes on the blocks. i went from 42.75" from floor to wheel well in back to 48 with the 1" block and add a pack. When you air up these bags, its crazy how much they raise the truck when empty. I keep them down around 15lbs.
Scooter29
Mar 20, 2021
Thanks for the reply, I currently have timbergrove airbags and was just thinking about switching to Carli bags. I only lose about 1” of down travel with mine connected at the axle so not too concerned. Was more after the smoother function of Carli’s tapered bags vs the double bellows for when unloaded. I run my bags at 0psi at ride height as when compressed they will still build a little pressure and not completely collapse.
