How useful do you find the Towing Tech Group?
jm888
Mar 5, 2021
I am just wondering how useful you find the stuff in this package. I guess it depends on which route I go because in a Laramie, it is only like $800 but in a Big Horn, it is $2200, which then might make it worth it to just upgrade to a Laramie.
farmallboy
Stump Killer
May 23, 2020
5th wheel or gooseneck hookup quantity might help sway your decision. I own a gooseneck without the ttg and admit I don't tow that trailer often but the camera would prob save me at least 2 "get out check"'s
jm888
Mar 5, 2021
I would only be pulling a bumper pull. I guess I am not realizing how the mirror mount cameras would be useful. Wouldn't they just show the same thing you would see looking in the mirrors?
They show you downward view it would have been nice to have where i had to jamb a 5th wheel this weekend
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
The mirror cameras are also very useful if you go 4 wheeling and have to pull in the mirrors due to width.
Frank
Sep 29, 2020
Missouri
I found them disorienting. I also found it awkward to stop what I was doing to pan them left and right to see what the mirrors already show. But I don't like any cameras for towing, nit even rear view.
See they could be handy in some scenarios like where i had to jackknife a camper into someones back yard this weekend i had low stuff by the sides of the truck i could not see and had to be careful not to hit
Frank
Sep 29, 2020
Missouri
I'll have to take a second look. I like the mirrors aiming down in reverse, I take it the camera will display further forward then mirrors?
Im not sure it is more of an assumption but even with mirrors facing down you cant see for the front end swing.... if you dont mind showing what kind of field of view it has that would be awesome
jm888
Mar 5, 2021
Would the front park assist feature help at all in warning you if you are about to hit something from the front end swinging out too far, or is the more centered on the straight on front end of the truck rather than the front corners?
r440
Nov 26, 2020
it should , my Ram 2019 1500 does
Bigb10b
Feb 8, 2021
The only thing I don’t like about the towing tech package is the black and white lines around the truck on the Birdseye view. Wish I could get rid of that.
Frank
Sep 29, 2020
Missouri
I wouldn't use the sensors to navigate the truck. They are going off in the red zone with plenty of space left to maneuver and they don't tell you where the obstacle is with much accuracy. And they won't pick up when you are making a tight turn and the front wheel or quarter panel is about to hit something in the periphery.
jm888
Mar 5, 2021
So can anyone verify if you can see the front of the truck, or the front corners of the truck in any of the cameras?
lgarrison34
Jun 29, 2020
The overhead 360 view is what I use mostly to tell where the front corners are in tight spaces.
Frank
Sep 29, 2020
Missouri
I'm pretty sure you can turn it off. I swear I turned it off in mine but I like it and put it back.
jm888
Mar 5, 2021
I just realized if you want the 12" screen along with some other upgrades on the Big Horn, the Technology package is actually a good way to go. I had already added the LED headlamps and the Alpine system, which are about $1400 alone. If you want the 12 inch screen, which is $2000, adding the technology package has all 3 of those items for $3000 and included all of the cameras and stuff in the towing group. In this case, it ends up a lot less than the Laramie because I don't believe the 12 inch screen is offered in a package on the Laramie.
